Adding a manifold heater to an engine
JD Jim A
12-12-2004 19:58:45
I've spent some time around the newer John Deere 7000 20 series, and noticed that they have a mainfold heater, which looks like a big glow plug. I've got a IH 756 with a D-310 that is a bit of a hard starter. The coolant heater helps, and it does have the ether-assist, but I've never been too crazy about using ether. I've thought about removing the ether can and trying a manifold heater from a newer JD. Think it would make a difference? The manifold already has two large threaded holes that are plugged, mabey I could screw the heater into one of these? How should I wire it, use the old ether button and a relay? Anything to look out for or any reason why this wouldn't work?
