JD 24t and NH 269 balers
Bill in Western
02-11-2004 07:32:02
I was just wondering about your opinions of these two balers. I need to decide between them and am looking for insight to make a decision. Thanks to all.
Mark
02-12-2004 07:55:41
 Re: JD 24t and NH 269 balers in reply to Bill in Western Iowa, 02-11-2004 07:32:02
Have a 24t which I bought last year for $700. It was shedded and the provious owner knew, not only what a grease gun was, but also how and when to use it. As a result it ties first time, every time. Saying that for wire is easy; it just twists it. For string, the baler has to tie a knot. Not bad. My first sq baler.
I couldn't decide between wire and twine and the twine became available first (and about $2700 cheaper than the cheapest 300 series (wire) JD aroundso I bought that. Only problem is rats eat the strings (bad); don't have wire (that you can't see) loose in the pasture to get into your brush hog so it can throw it at you and your rear tractor tires (good). Twine is easier to handle on the consumption end of the process (good).
Pieve: The only part worn is the flywheel (very slight wobble) and as a result you have to be sure and keep the shear pins (specially tempered 1/4" bolts from your JD dealer)loose and adjust your ground speed and PTO to the nature of the grass bailing. Sometimes I can bale 30 bales B4 shearing a pin, other times every other bale.
I only put up a few hundred bales a year and I can put up with the nuisance considering I only paid $700 for the machine and it puts out a really nice bale.
Mark
robert
02-11-2004 09:24:14
had a super 68 and a 273 both were exceptional machines.
