'50 B What kind of battery?
Shapshot
12-12-2004 15:23:36
I have a '50 B and bought a new 6v. Tractor Supply $30 battery this summer. It turned it over ok when it was warm, but now with 30 deg. temps, its real slow. I tried a 12v., and it turns over good. I would like to keep a 6v., but let me know what you all think. 6v. (what kind and size?) or 12v. In Michigan it gets even colder than the 30 deg. now. Thanks. Slapshot (ps this is my first tractor)
DW
12-13-2004 10:30:10
 Re: '50 B What kind of battery? in reply to Shapshot, 12-12-2004 15:23:36
I converted my 50 "B" to 12 volt about twenty years ago. My starter repair man told me that the 6 volt starter wouldn't last 2 weeks. Guess what/ .... It still works just fine, ..alternater charging and that tractor will start at -20F anyday. Just my 2cents worth. Also I use 10W/30 oil. Good luck. DW
Slapshot
12-13-2004 03:18:55
The starter (which was completly worn out according to the rebuilder) was all gone thru ($140), bought a new power wire from John Brillman for his tractor, and a new braided correct ground strap from Robert Campbell in the Upper Peninsula of Mich. I did have a problem with the tractor seat/battery box not grounding to the frame, but I took it apart and ground down to clean metal, greased it and put it back together.
Jim Nauert
12-13-2004 01:57:06
When i start my 51 B in cold weather i like to open the petcocks up an pull back on the clutch handle. Also if you don't use the tractor that often you might want to put a battery maintainer on it. This will keep it at full charge till you need it. walmart sells a nifty little on that goes from 6 to 12 volt. I use sae 30 oil all year but you might want to cosider a different oil for winter. Good luck.
John T
12-12-2004 19:10:18
Shap, if you want to keep it 6 volts and want her to start in extreme cold temperatures (especially if she has to sit outdoors) youre gonna need ALL THE BELOW:
1) About the biggest (physical size) and highest amp/hr or CCA rated heavy duty 6 volt battery that will fit in the compartment. If you dont mind the expense, you may wanna consider one of those new high performance circular cell type gel batteries. FIT has tried one I believe???
2) At least 00 Gauge Battery and Starter and Ground Cables, with all good clean tight connections, plus a good starter n good starter switch.
3) A very well tuned engine, including good cap n rotor n wires n plugs n points etc., with decent compression (good valves n rings). I would also keep Sta Bil in the gas n be sure its fresh n clean n water free.
Now, if you dont have all that, you could consider changing her over to 12 volts and she may still start, even where all the above isnt quite as good condition.
Good Luck n God Bless
John T in Indiana
old
12-12-2004 16:30:36
How the starter? it maybe getting weak and if so it will not turn over as it should.
