Ben, if its a Delco distributor ignition and theres no spark, heres a troubleshootign procedure: PRELIMINARY, remove the cap and insure the points are opening n closing as the engine is turned over,,,,, ,,,they are gapped to open to 0.022 on high cam,,,,,and are NOT all burned or pitted or carboned up badly, and replace them if so. You might try cleaning the surfaces with a point file n see if she will run then. To be sure the condensor isnt shorted out, temporarily remove its wire from the points n see if she fires then, if so, it may be bad/shorted so replace it. If the points are good and gapped and open n close and the condensors NOT shorted out but still no fire, are you sure the plugs are good??? Try if just the plug wires removed from the plugs will make a spark between their ends when held 1/8 from frame and shes on n turned over??? If the wires fire but not the plugs, its bad plugs. If the plugs or points arent the problem but still no fire, proceed as below: 1) First, see if the coil is firing at least but maybe the plugs arent??? To do that, remove the coil wire from the distributor (leave coil end intact into coil tower),,,,, ,place its bare end to within 1/8 inch from tractor metal, turn her on n crank her over n see if the coil wire fires that gap????? ?? If so BUT NOT THE PLUGS OR PLUG WIRES its a cap or rotor problem or plug wire or plug problem. 2) If the coil wire isnt ever firing, proceed as follows: 3) Take a test lamp with one lead to frame and other to the coils lil primary input (NOT to distributor) terminal,,,,, turn the ignition ON and THE LAMP MUST LIGHT UP. If NOT, its either a bad ignition switch,,,,, ,or the wires bad/open between switch n coil,,,,, ,or if it has an in line Ballast Resistor, it could be bad/open. You might "Hot Wire" the coil by running a hot 12 volt lead (like from battery or BAT terminal on Voltage Regulator) direct to the coils lil high (NOT to distributor) side terminal n see if she firs then. If so, again, look for a bad switch or open wire or open ballast (if it has one). NOTE those switches can go bad (which hot wiring will make run) or theres no hot feed to the switch. A test lamp should glow on the switches hot BAT input terminal at all times, but then only glow on its IGN output terminal when ON. If it has a 6 volt coil and a Ballast Resistor, it (ceramic block maybe 1/2 x 1/2 x 3 inches) will be series in line between the ignition switches IGN output terminal and the coil. They can open up in which case theres no voltage on their to coil terminal when ignition switch is ON. 4) If a test lamp glows on the coils high input terminal (i.e. switch n wires n any ballast are all okay),,,,, ,NEXT place it over on the coils other terminal that leads to the distributor,,,,, ,,,turn her on n crank her over,,,,,AND THE LAMP MUST FLASH ON AND OFF. a) If it never comes ON, either the coils primary is bad/open, or the points never open or are shorted, or the condensors shorted, or a wire is shorted. b) If it never goes OFF, either the points are bad or not closing (or carboned up very badly) or theres an open wire between the coil n distributor to points to ground. Try the simpe thigns first like check the points and their surfaces and gap and the plugs and then see if she has power to the coil when switched ON cuz she cant ever fire till there is, which hot wiring may find. If you need more help I had two articles published in Green Magazine on Ignition Troubleshootign and another on Ballast Resistors I could send you, but hopefully, the above simple troubleshootign may get you going as its usually just bad points or a bad switch or plugs or a bad/shorted condensor or maybe a bad coil or an open ballast resistor. John T in Indiana [email protected] Good luck n God Bless
