Hand start flywheel
George G
12-11-2004 14:57:11
I have a hand start JD flywheel out in the shop. I think it's for a A, but I don't know. The number cast on the back is A29R. Plus, I have two A's setting down back. Both are early electric start. One's S/N tag is so rusted up,you can't read it. Is there another way to tell the year? Thanks for any information given.
Will P
12-11-2004 23:25:43
 Re: Hand start flywheel in reply to George G, 12-11-2004 14:57:11
You state that the serial tag is "rusted" up. Steel tags where used on late 42, 43 and 44 tractors. War tractors.Otherwise the tags were brass or aluminum. Which won"t rust. Is the frame cast iron or angle steel? Does it have a big cap on the radiator or a small pressure type cap?
Will P
