Duben, to try n explain things without a wiring diagram, I will give you a description of whats going on and you can probably wire her up absent any diagram. 1) The Ammeter has 2 terminals, a SUPPLY SIDE and a LOAD SIDE. The SUPPLY side requires hot 12 volts, often direct from the batterys hot ungrounded post, or from the big hot lug at the starter. NOTE thats NOT any lil extra side terminal on a mechanical starter switch, its the same place the big main battery cables attaches to it. REGARDLESS, WIRE THE AMMETERS HOT SUPPLY TERMINAL TO 12 VOLTS, BATTERY OR BIG STARTER LUG. 2) The ammeters other LOAD TERMINAL. This is where loads such as lights or ignition (via the switch) are fed power when using 3 wire (BAT ARM FLD) Voltage Regulators PLUS the Voltage Regulator's BAT terminal is connected. On 4 wire (BAT ARM FLD LOAD) VR systems, the VR's BAT is still wired there BUT loads like lights n ignition are fed form that LOAD terminal on the VR. 3) On tractors equipped with a 6 volt coil and an external Ballast resistor plus a by pass starting system, that extra lil side terminal on the starter switch is wired to either the coils high input (NOT to distributor) terminal or the Ballast resistors low (To coil NOT from switch) terminal for full unballasted battery voltage on the coil while cranking. Hope this helps, post back any questions, Good Luck n God Bless John T in Indiana
