Front spoke wheels
Randy G.
12-11-2004 09:15:56
I have a set of JD front spoke F & H 16" wheels. Wheel number is HC 176 0r 8 and cap cover number is B920R. Would it be proper to put these on my 1938 long frame B or did they only come with pressed steel fronts? If they did not come on that year of B, what would be a good price for me to sell them for? They have been sandblasted and painted, inside of one wheel has been welded around the center otherwise in great shape. Any help is greatly appreciated. Randy G.
Duane Larson
12-11-2004 10:52:16
 Re: Front spoke wheels in reply to Randy G., 12-11-2004 09:15:56
Randy,
Are you sure they are 16"? The standard issue round spoke fronts for B1000 - 29630 were F&H HC176, with a 3.00Dx15" rim. At 29631 the Bs came with the AB1023 (version 1) - a non-reversible pressed steel wheel with 10 rivets holding the wheel center to the (3.00Dx15") rim. Somewhere around mid '38 they changed to AB1023 version 2; that wheel center had four scallops at the wheel-rim interface, and each scallop was attached to the rim with 2 rivets, for a total of 8 rivets.
If the round spokes are something other than 15", post back and we'll go from there.
Randy G.
12-12-2004 13:42:13
 Re: Front spoke wheels in reply to Duane Larson, 12-11-2004 10:52:16
Duane, I stood the wheels on edge on the floor and measured from the floor to the top of the wheel and it does indeed measure 16" and have 10 spokes on each wheel ,if that helps. The cast numbers are as I mentioned earlier. They did not come on my US B, it has the pressed fronts on it now. Am I measurering the wrong? Let me know my next step. Randy
Duane Larson
12-12-2004 15:23:18
 Re: Front spoke wheels in reply to Randy G., 12-12-2004 13:42:13
Randy,
Rim measurements are made where the bead of the tire seats, not the outside lip to lip. So, to measure the rim width, on the inside of the rim measure across the rim, and you should have 3.00". For the diameter, perhaps it is easiest to measure the circumference around the flat spot where the tire bead sits, and divide by pi (3.14) to get the diameter. It should be close to 15" for your tire.
FWIW, the lip to lip distance across a 15" tire is very close to 4.0", and the lip to lip distance corresponding to the diameter is about 16 3/16". But that is not the conventional way to measure a rim, as noted above.
Randy G.
12-13-2004 21:04:30
 Re: Front spoke wheels in reply to Duane Larson, 12-12-2004 15:23:18
Duane, the wheels do measure 3" wide and 15" at the bead. Would it be ok to put them on my 38 B? If not, what asking price should I put on them if I sell them? Also, the rear wheels are spoke wheels with cast in hubs. Are these the ones that go for high dollars? Just wondering. Thanks alot for teaching me a thing or two.
Randy
