B Distributor Question
Gr8Bald1
12-10-2004 14:28:59
When I bought the B, it had a ballast resistor going to the coil. I've converted my generator to 12 volts and I have a 12 volt coil. Do I still need the resistor or would I only need the resistor if I had a 6 volt coil??
John T
12-10-2004 20:42:45
 Re: B Distributor Question in reply to Gr8Bald1, 12-10-2004 14:28:59
Gr8, Duane has ya covered regarding no necessity of an external ballast provided you have the internally ballasted 12 volt coil (around 2.8 to a lil over 3 ohms primary as measured between its lil + and - terminals) but Im wonderign why you had a ballast in the first place, was it 6 volts prior to your conversion????
John T
Gr8Bald1
12-10-2004 21:56:31
 Re: B Distributor Question in reply to John T, 12-10-2004 20:42:45
Duane, thanks for the info...that'll clean things up a bit. It IS a Delco distributor. John T, I was sorta scratching my head as to why it had the resistor when I got it. It had already been converted with an alternator hanging out the right side about a mile and a half with the resistor and a 3-legged flat, square computer chip-looking doodad in series between the alternator and the resistor. I'm no EE, but I have worked on B-52 radar and avionics for the past 18 years and had no idea for all the hub bub. Any idea what the 3-legged gadget was? (I removed it when I did a basic re-wire before the complete teardown and everything worked fine.)
John T
12-11-2004 07:14:14
 Re: B Distributor Question in reply to Gr8Bald1, 12-10-2004 21:56:31
Gr8, from what you just added, its making a lil more sense now. My suspicion is the resistor youre talking about and the chip looking doo dad was NOT an ignition Ballast Resistor, but a circuit to excite a 3 wire GM alternator. How those circuits work is to take 12 volts (when ignition switched on like the coil feed) and feed a circuit consisting of a 10 ohm small wattage (NOT like a typical 25 watt Power Ballast Ignition resistor) resistor and a Diode (rectifier) to power up/excite the lil 1R side terminal on like a GM 10 SI 3 wire Alternator.
Therefore, I think you didnt have an ignition ballast, just the circuit described above to excite the alternator. The diode is a current limiter to protect the Alternators diodes while the diode/rectifier is to prevent alternator feedback so the tractor dies if the ignition is turned OFF.
What Alternator do you have and how is it excited. A true one wire requires no external excitation, while the GM 10SI 3 wire does, so she will kick in and start charging at low RPM's
John T
Gr8Bald1
12-11-2004 23:12:59
 Re: B Distributor Question in reply to John T, 12-11-2004 07:14:14
John T, I think you hit the nail right on the head. At the same time I re-wired, I swapped in a 1-wire. I guess that explains why all worked well without the thingamajig afterwards. I now have a freshly rebuilt generator (converted to 12V) ready to slam on when I get that far. Thanks for solving this one for me!
Duane Larson
12-10-2004 16:23:11
Gr8Bald1,
If you have a 12V battery and generator, and a 12V coil, you do not need a ballast resistor (assuming you have a Delco Remy distributor), unless the coil is explicitly labeled "use with external resistor". The resistance of a 12V coil primary (measured at the two screw terminals) should be about 3 ohms with a good ohmmeter.
If you have a Wico XB distributor (that looks like a magneto), you will need the extra ballast resistor in the small box attached to the outside of the distributor.
