6x4 Gator
kingsbury
12-10-2004 05:39:39
I RECENTLY PURCHASED A 94 GATOR THE KAWASAKI MOTOR IS IN PIECES.THE VALVE COVER SAYS THIS MOTOR IS A FD620D (2O HP.). I WOULD LIKE TO KNOW IF THIS IS THE CORRECT MOTOR AND WHERE CAN I FIND A REPLACEMENT. THANKS
Henry J
12-10-2004 11:40:08
 Re: 6x4 Gator in reply to kingsbury, 12-10-2004 05:39:39
Kingsbury
If you are mechanically inclined and have some basic tools, it might be worth looking into what was wrong with the basket case. just guessing from posts it either ate the fiber canshft gears or swallowed a valve.
I just went thru the swallowed valve deal and if it weren't for having to buy a new head, it wouldn't have been that bad. three valves, head, piston, rings, seals and gasgets came in just under 500.
Just a thought, there will be a lot of ney sayers, but when it comes to plunking down the big bucks who knows. Right now mine runs like new for a third of the money. Depends on the budget for me.
happy holidays
KINGSBURY
12-14-2004 07:49:51
 Re: 6x4 Gator in reply to Henry J, 12-10-2004 11:40:08
I NEED A NEW BLOCK. I HAVE FOUND A 20HP. BUT IT DOES NOT HAVE A TAPPERED OUTPUT SHAFT. ARE THERE ANY LINKS OUT THERE THAT COVER PRIMARLY THE GATOR? THANK YOU
buickanddeere
12-10-2004 06:03:27
A factory parts manual should show and tell everything.1-800-522-7448 and are cheap in price. 20 HP was stock. Don't try larger engine for more speed. This shop and dozens of others sell small engines and even kits to swap from one manufacture to another.
www.smallenginewarehouse.com
