630 over charging
Terry
02-10-2004 21:37:32
630 converted to 12volts. the battery slid and the battery post touched on the battery box the gauge showed the tractor charging a lot. straighten the battery out but now the tractor wont start. It is getting gas and I have spark on both plugs but it wont fire! could I have shorted something out? so I am getting spark but not strong enought. Thanks Terry
Terry
02-12-2004 07:12:01
 Re: 630 over charging in reply to Terry, 02-10-2004 21:37:32
John and Clooney Thanks you both helped get me on the right tract.
-I tried the plug gapped at 3/16 and had good spark on both side. with battery charger on the batterys.
-checked fuel flow as you describer and it was not flowing as fast as you recommended.
-took the sediment bowl off and instead of a nice fan spray it was coming in on just two sides. so I beleave the problem is between the sediment bowl and the tank.
Thanks again I will let you know what I find after I take it apart. Terry
Clooney
02-11-2004 10:05:35
Terry, first off your 630 wasn�t converted to 12 volts! It has always been 12 volts as that is how the 630�s came from the factory.. Did you mean to say it was converted to a single 12 volt battery?
~If you are getting gas & a good spark it should start..
~Probably the place to start is with the spark� Take a [known good] spark plug [any type],, then open the plug gap to 3/16� [use a 3/16� drill bit as a gap gage],, then install that 3/16� gap spark plug in one plug wire at a time & lay on the engine block, then crank the engine & look for a bluish colored spark to jump that 3/16� gap [leave the original plugs in for cranking drag] .. If you get a bluish colored spark to jump that 3/16� gap multiple times in a row you have plenty of spark to start it.. SO! replace your spark plugs with new ones & try starting it.. You might just have fouled spark plugs, [a very common problem]�.
~If you don�t get a bluish colored spark to jump that 3/16� gap you have an ignition system problems [or a low battery] ..
~First try hooking a battery charger [or jump from another vehicle] to your battery & trying it again.. A low battery can really lower the spark during cranking. Maybe when your battery shorted out it killed a cell & your battery is now too low to both crank & power the coil..
~If the battery charger [or jumping] doesn�t help, then try running a test jumper wire from the battery�s non grounded post to the coil�s [non distributor side] power terminal & see if you get a better spark [or try starting it] .. If you do get a better spark then suspect a an open by-pass starting wire from the starter to the coil side of the ballast resistor [that by-pass wire by-passes the ballast resistor for more power to the coil during starting].. If still no good spark put a test light on the distributor side of the coil & crank the engine. That test light should flash off & on as the engine is cranked, if not you have distributor problems like oxidized points, a failed condenser or open wire. If the light does flash off & on then remove the coil wire from the distributor & hold to within 3/16� of the block & see if it will jump that 3/16� gap there, if so but it won�t jump that 3/16� gap at the ends of the plug wires you could have a bad dist cap, or bad rotor, or leaking plug wires, or incorrect plug wires [make sure they are solid metal core & not automotive TVRS carbon core wires]..
~If you do have a good spark per above you might want to look for water in the air cleaner oil cup, or water in the fuel, or the carb choke plate not working correctly inside the carb [just because the choke rod moves & the carb choke lever moves doesn�t mean your choke plate inside the carb is actually working correctly [pull the carb�s choke cover off & look to be sure the choke shaft is moving when the choke rod is pulled]..
~About all that�s left is low compression [run a cold cranking compression test], or poor fuel flow to & THROUGH the carb.. To test that remove the carb�s bottom drain plug, then unscrew the knurled nut on top of the fuel strainer & hold it down,, you need to see a pencil sized stream of fuel flowing for at least 30 seconds.. If you don�t have that look for a plugged strainer, plugged carb inlet filter, ice in the fuel tank or carb, or other fuel restriction�
~Quick hint� If you have good fuel flow & a good spark try new spark plugs as that is the number one reason of not starting..
Post back or E-Mail with any questions & I will be more than glad to answer them for you..
JDClooney
John T
02-11-2004 09:12:21
Terry, its a fairly wide open question with different possible problems but we gotta start somewhere so I will begin by tossing out a few electrical basics to look at. When you say it wont start but has spark, Im assuming you mean she cranks over okay right????? ??? If she wont crank, POST BACK for different troubleshooting tips.
1) It was always 12 volts, maybe it got converted from two six volt batteries in series to a single 12 sometime in its life.
2) If the ungrounded battery post got partially shorted out, the Voltage Regulator (VR) could have kicked up to the high max charge rate, it may be fine now. Its possible a wire may have burned up in the ignition circuit or ballast or ballast by pass circuit when things shorted out. See if theres any smaller wires off the ungrounded battery post or starter or solenoid that got burned off or disconnected which could be weakening or loose power to the ign switch. Are the lights and other elec items still working??? Ammeter still swing to discharge if lights turned on???? Battery not shot is it????? ??
CHECK THE PLUGS, sometimes once fouled, they never are as good, if in doubt or fouled, try a fresh set of plugs !!!!! !!!!! !! Be sure the cap is clean and free of oil or moisture or cracks or carbon traces.
COMPARE the spark out the coil wire to ground versus at the plugs.
MAKE SURE shes gettign gas to the cylinders and the chokes working.
CHECK AND LOAD TEST THE BATTERY, if its real weak it can cause hard starting. Be sure it has electrolyte above all plates and none are gray or milky looking. Maybe charge it up and try it or use a good substitute battery and try it???
Test the plugs firing BOTH with them out of the cylinders (low load on battery since no compression) and then with plugs in cylinders to cause compression (use diff plugs to wires to compare loaded versus unloaded sparks). If battery is bad, cranking drags voltage down weakening spark causing hard starting.
3) IMPORTANT
You say it has spark????? So Im wondering if it has spark BOTHHHHH HHH when the starter motor is cranking it PLUSSSSS SSS when the start motor is no longer engaged????? ???? It has an ignition ballast resistor PLUS a ballast by pass circuit, so the sparks hotter ONLY WHILE CRANKING, then the ballast is back in the circuit but it still sparks if alls correct.
a) If the ballast is open but the by pass system works, it can be sparking when cranking BUT STOP FIRING when you stop cranking.
b) If the ignition and ballast circuit is okay but the by pass is not, it dont have as good a spark when cranking (still should start however if rest is in decent shape)
BALLAST AND BY PASS TESTING
Remove the plugs with their wires attached
and plug sides frame grounded and see if with ignition ON they spark BOTH when cranking and when the flywheels still coasting. If they STOP firing immediately when cranking stops (but flywheel still coasting), the ballast or ign circuit is bad and she may try n start but cant run. (Ballast may be burned open)
4) Place a voltmeter on the coils high (NOT to distributoir) side. When you turn the ignition on, voltage should be present there. IF NOT, the ballast may be open or the ign switch bad or the circuit (switch to and thru ballast to coil) has a bad wire. THIS ASSUMES THE CIRCUIT FEEDING THE SWITCH IS GOOD (starter post to and thru ammeter to switch)
5) Next leave the ign OFF, have a voltmeter on the coils high (NOT to distributor) side and crank the engine (may have to hot wire the cranking in event ign switch dont allow such). Voltage should appear there if the ballast by pass circuit is working.
There has to be a good circuit from EITHER the ungrounded batery post,,,,, , to the starter post where applicable,,,,, , to and thru the ammeter,,,,, to the ign switch,,,,, ,,, to and thru the ballast,,,,, , to and thru the coils primary (lil + and - terminals) to and thru the closed points to ground.
YOU GOTTA HAVE voltage to the coils high input side when the ign is turned on!!!!! ! IF NOT, ballast is open or ign circuit bad.
THE VOLTAGE there should rise some when the engine is being cranked if the ballast by pass circuit is working. Its a wire from the solenopid to the coils high side.
You might also check the fuel and choking, but these are a few electrical things to look at.
Post back or e mail me aT [email protected] OR CALL Me AT 812-824-4608 IF YOU WANNA DISCUSS
Send me ur e mail addres if u want a Wirign Diagram.
LET ME KNOW IF THE ENGINE CRANKS AS THIS POST ASSUMES!!!!! !!!!!
Good Luck n God Bless
John T Nordhoff
