G pistons
Larry806
02-10-2004 21:04:42
I got the pistons out of a G block tonight They have 45 over marked on the face On the inside where the pin goes through looks like no. P 2108 on down inside its either MWM or WMW I'm thinking M&W but does anyone know for sure Thank You Larry
Duane Larson
02-10-2004 22:24:28
 Re: G pistons in reply to Larry806, 02-10-2004 21:04:42
Larry806,
Your number is consistent with a M&W catalog from about 1971, which shows a P-2108P piston as 6 1/8" piston, which comes in std-.045-.090-.125 oversize. It takes a 6208 set of rings and W-2108 pin.
Larry806
02-11-2004 07:16:57
 Re: Re: G pistons in reply to Duane Larson, 02-10-2004 22:24:28
Thank you for your reply Duane That helps a lot Larry
