2020 brake pedal
unclechan
12-09-2004 17:55:37
My right brake pedal will not return to normal position after pressing down on the pedal. I assume the spring inside the brake pedal assembly is bad or something. Any ideas? If it is the spring, is it hard or involved to take apart and replace? The left brake works normally and both brakes work well, you just have to pull the right pedal back to release the pedal. It comes back a little but drags somewhat if not pulled back completely.
bubba
12-09-2004 19:04:50
 Re: 2020 brake pedal in reply to unclechan, 12-09-2004 17:55:37
Most likely one of two places.Either the shaft the pedal rides on is rusty or the top of the operating piston is full of crud or rust.Disconnect the pedal and see if it moves freely on the shaft.If it does, remove the rubber boot and check under it for rust or crud.You may get the problem corrected with liberal amounts of penetrating oil while working the affected part back and forth by hand.
david val
12-10-2004 03:49:03
 Re: 2020 brake pedal in reply to bubba, 12-09-2004 19:04:50
it's a bit different in 2020, but the culprit is probably the pedal shaft/bushing. try applying a lot of penetrating oil to the pedal/shaft area and 'work' the pedals many times, repeat the process for a few days. if that dosen't work,the pedals have to be removed for rust removal (not that simple when stuck with rust).
david
