Gaskets
Walter Squires
12-09-2004 08:40:18
I got a set of NOS gaskets for my JD H yesterday and they are pretty dried out and hard, would you try to soften them up with something and if yes what with.
WTW
12-09-2004 13:16:20
 Re: Gaskets in reply to Walter Squires, 12-09-2004 08:40:18
Walter, I run across the same thing with old gaskets. I usually take a cake pan with some warm water and just let them soak, check them once in awhile as they will soften up and enlarge at a slow pace. When the bolt holes line up I pat dry them with a cotton towel and spray a light coat of high tack sealant on them and install them before they dry completely out or they will shrink right back. When you tighten the bolts down they usually ooze a little water from them but that won't hurt a thing the gasket will function and seal just fine. You have nothing to loose and every thing to gain, it will work. Good Luck, DW
F-I-T
12-09-2004 11:37:29
I have used a steam iron. Steam them moist, iron them flat.
Frank
Mike M
12-09-2004 09:31:54
That's the trouble with old gaskets,sometimes it is better to just make new ones.You can soak them in water it should help straighten them out,then I dry some inbetween old newspapers install before they shrink back.
