Early 60 PTO
Jared
02-10-2004 20:22:20
i know this is a broad question, but the pto does not work on my early 60.
i was told that a number of years ago, the pto was getting warm when it was used, and so my grandfather, the last owner, took it in to a dealership to have it fixed. the guy told my grandpa that the pto should work, but it doesent, and that was several years ago.
recieltly i tried to engage the pto, and now it is stuck in the on possiton and the power shaft will not turn at all.
could the warm pto be a result of the pto clutch slipping, and could the guy not have put it back together right?
or could it be somthing else?
any and all feed back will be helpful.
jared
Clooney
02-11-2004 03:40:41
 Re: Early 60 PTO in reply to Jared, 02-10-2004 20:22:20
Jared, By your post it sounds like you have the live PTO on that 60?
~First do you have the PTO lever up by the trans shift lever engaged?? If not the PTO will never work. If the front lever is engaged & the PTO still doesn't work you have other problems..
~Start by starting the tractor, then idling it down.. Then try to easily engage the front PTO lever.. If you hear a grinding while engaging, stop & don�t force it any farther. If it grinds while trying to engage at least the front gears are trying to work.. If you don�t get a grinding while engaging the front lever you have major problems with the front gear set or shifter on the PTO [you will need to get a repair manual at that point]..
~If the front gears grind while trying to engage you will probably have to pull the rear PTO clutch housing off & take a look inside for burnt clutches or other problems like trans gear oil in the rear PTO housing [again you will need a manual]� If you have trans gear oil in the rear PTO housing [give it the sniff test] you have major problems & the whole rear of the tractor will have to come off..
~Look into it a little farther & post back or E-Mail with what you find. If you can get a little closer to where the problem is we can help you repair it�
[email protected]
Jared
02-11-2004 17:57:53
 Re: Re: Early 60 PTO in reply to Clooney , 02-11-2004 03:40:41
thanks for your help, i will try to get at that as soon as possible. right now i am busy with school and work.
again, thanks for your help.
Jared
