39B ring job - easy or difficult?
David Lewis
12-08-2004 19:01:32
Need new rings - am blowing blue smoke
right now. Seems like an easy job - anything I need to watch out for? Where do I buy the clamp to hold the rings in tight when I put the piston back into the cylinder, and where do I buy calipers to measure the cylinder diameter?
Hate to be doing this job in an unheated barn
in December. Hey ho..... Happy Holidays!
jgc
12-10-2004 10:44:11
 Re: 39B ring job - easy or difficult? in reply to David Lewis, 12-08-2004 19:01:32
David,
See my notes below.
Need new rings - am blowing blue smoke right now. YES, RINGS AND/OR VALVE GUIDES.
Seems like an easy job - anything I need to watch out for? IT'S A BIG JOB BUT IT IS STRAIGHT-FORWARD.
I WOULD GET THE BLOCK AND HEAD PLANED TO MAKE SURE THAT YOU'VE GOT GOOD SEALING SURFACES FOR THE HEAD GASKET. THERE ARE MANY OPINIONS ABOUT USING SEALER ON THE HEAD GASKET,, OR ASSEMBLING IT DRY!
Where do I buy the clamp to hold the rings in tight when I put the piston back into the cylinder, YOU CAN BORROW OR BUY A RING COMPRESSOR TOOL. IT IS A BAND OF SPRING STEEL WITH BANDS ON THE OUTSIDE THAT TIGHTEN AROUND THE PISTON AND SQUEEZE THE RINGS IN. GENTLY TAP THE PISTON BACK INTO THE BORE. THERE ARE SMALL BUMPS ON THE SPRING STEEL THE CATCH THE EDGE OF THE BORE AND HOLD THE TOOL BACK - FROM JAMMING IN THE ENTRANCE TO THE BORE.
I WOULD USE THE SUGGESTION OF LONG FEELER GAUGES THAT SOMEONE DESCRIBED. CHEAP MEASURING GAUGES ARE NOT WORTH BUYING, AND GOOD QUALITY ONES LIKE STARRET OR MITUTOYO ARE EXPENSIVE FOR BORES THIS LARGE, UNLESS YOU PLAN TO DO A BUNCH OF ENGINES.
A GOOD JD SHOP MANUAL IF STILL AVAILABLE WILL BE A GOOD INVESTMENT. THE JD PARTS BOOKS ARE VERY USEFUL AS WELL.
JGC
Lee B
12-09-2004 23:41:57
Easy? No, but very straight forward. A better tool to use for the novice might be a set of very long feeler gauges for use in determining how much clearance you have between piston skirt and cylinder wall. They make them just for that purpose about 18 inches long (NAPA $30). Take the rings off and put piston and gauge back in bore, pull out gauge to feel if it drags any. Start small and go bigger until you feel it dragging noticeably and that's your clearance. Purchasing inside and outside micrometers in the sizes needed to measure it directly will blow your budget. Take them to town and let somebody who already paid for his measure them for you. Any machine shop with large enough equipment to bore your cylinders will fall over backwards to measure them while you watch just for the chance to bore the block for you. If you go that route you'll need new pistons and rings as well and those are high dollar items too.
Ring compressor not really needed, use your all your fingers one ring at a time and walk them back in. You might want to trim your fingernails before you start as they will get some trimming the hard way otherwise.
When I did my 43 A, I measured for clearance per feeler gauge above, noted that I was way overbore, needed boring, new pistons and rings but just went with cross hatch with standard 3 stone deglazer, cleaned up pistons with oven cleaner and filed a new surface on the OD of my old rings and reused them. A hard charger with no smoke is the result and I'm very pleased with the whole budget for the job. BUT I am a very experianced mechanic who has been reusing rings for decades, your milage may vary.
jdtruble
12-09-2004 07:23:11
i would also recommend the rebore, as far as the rings i have always had good luck by compressing the rings one at a time and sliding the piston in the bore.
Mike M
12-08-2004 19:11:23
There's a good chance you may need a bore job too. You might try www.wttool.com for mics. Auto parts store should be able to get a ring compressor. I don't know for sure on that 39 but on an unstyled,which yours is close to,you don't need a ring compressor as JD had enough room in the cylinder wall to build in a tapered step to act as a ring compressor.Just start them in and pusher back.
