630 wireing harness
jacksun
12-08-2004 18:45:59
does anyone make a reproduction wiring harness for a 630 mine is chopped up they even used pieces of extension cords. also will this tractor handle a 3-14 3pt plow in heavy soil?
Dan in Ohio
12-09-2004 22:15:22
 Re: 630 wireing harness in reply to jacksun, 12-08-2004 18:45:59
Jacksun, Try www.brillman.com for your wiring harness, I have also used Agi-Services wiring harness and have been satisfied.
HillBilly in Vegas
12-08-2004 19:39:47
 Re: 630 wiring harness in reply to jacksun, 12-08-2004 18:45:59
Try Agri-Services at www.wiringharnesses.com
I pull a 3-14 fully mounted plow behind my 620. It pulls them pretty well in 3rd gear in a semi heavy sandy-clay soil mix. Answering plowing questions can be subjective, so let me qualify that by saying the tractor runs strong. We recently rebuilt the motor and it has about 100 hours of use. Also, the tractor is heavy. The rear tires are new and loaded with fluid. I put two sets of wheel weights on it also. Now I could some front weights!
Mike M
12-08-2004 19:14:43
Have you tried JD for that harness ? Check with Stephen Equipment. If your 630 is not worn out it should be able to handle 3-14's.
