How should it be done
Don c
12-08-2004 07:57:34
Redoing my early 60, engine and trans. are good, didn't take apart, done the PTO and power-trol and a bunch of others things. Have been rolling it over by hand a couple times a week with flywheel, should I put anything in the cylinders to keep them lub. or just do as I have been doing, tractor has been down for about a year and it looks like it maybe another year before it runs again. Thanks Don c
old
12-08-2004 08:26:07
 Re: How should it be done in reply to Don c, 12-08-2004 07:57:34
If it where my tractor I'd put some tranny fluid in the cylinders and turn it over to get it on every inch of the cylinders etc. That way it isn't as likely to start to rust in there
Josh in Indiana
12-08-2004 13:50:23
 Re: How should it be done in reply to old, 12-08-2004 08:26:07
I have had good luck using Marvel mystery oil to coat the cylinders like that. Tranny fluid will work just as good but I thought I would throw another idea out there.
Merry Christmas,
Josh
P.S. It may not hurt to put some oil around the head so you dont end up with a stuck valve or something. Just my .02$
