G John Deere Questions
Jon F
12-08-2004 05:49:37
Just purchased a 1948 G John Deere with a powerblock. To determine how tired it is, what should the cranking speed compression be? What kind of horsepower will this engine make roughly?
Jak
12-08-2004 09:11:01
 Re: G John Deere Questions in reply to Jon F, 12-08-2004 05:49:37
If it is above 100 psi than you should be at least 55 hp maybe more if the carburator and timing are right.Jak
CMB
12-08-2004 08:37:08
Power blocks were sold by the old "Tractor Supply Co." They were available for "A", "B", & "G" tractors,and also for the first # series, I believe. They increased the bore size quite a bit. "A"s,& Early "B"s were enlarged by 1/2". In a "G" it went from 6 1/8" std to 6 1/2" . This resulted in, if I remember correctly, 464 cu in. That along with a substantial increase in compression ratio, and a "cold" manifold was advertised as producing 63hp at the PTO. Many years ago I put one in a '51 "G". Don't know if it produced the advertised HP, but the power increase from .125 over with 7-1 aluminum pistons (52 dynoed HP) was quite noticeable. I could pull 4-14s in third gear most of the time.As I have said before, with the power block that "G" would pass anything except a fuel barrel! Pulled really well, but it DID like it's fuel!
farmallman
12-08-2004 07:32:48
What is a powerblock? Does it increase the Hp? If not, I have a JD G that can give out 40pto hp and 35 drawbar hp.
