720 3 Point Return Spring, any tricks?
Soldier Tom
12-07-2004 17:24:21
O.K. I got the spring, now is there a trick to getting it on? I'm sure somebody has a neat idea to make it really easy on me.
Thanks in advance
~Walk in peace~
Soldier Tom
Maark
12-08-2004 07:17:04
 Re: 720 3 Point Return Spring, any tricks? in reply to Soldier Tom, 12-07-2004 17:24:21
Can't you remove the elephant ear that the spring hooks to and then hook the spring to the top three point arm and the elephant ear and use the weight of the lower casting to help pull it back down to the mounting bolts?
Ducknose Bob
12-07-2004 18:21:05
Bend it enough to insert a washer between several coils. This will lengthen it enough to install it, then remove the washers.
Soldier Tom
12-09-2004 15:23:09
 Re: 720 3 Point Return Spring, any tricks? in reply to Ducknose Bob, 12-07-2004 18:21:05
Thanks guys, everything I can learn helps that much more! Good ideas, both, and I never thought about either of em.
~Walk in peace~
