48 JD D clutch cover
Tony W.
12-07-2004 13:40:54
I have taken the clutch out to grase the bearing inside for the year and found that the cover itself does not look right. As the flinger grooves flinge the oil off the cover is to aloow it back the the gear sump. My cover is draing it to the ground, and allowing dirt into the oil. I think that a piece is missing. Am I thinkng wrong or is this the way it is to be? My uncle filled the drain with sealer to keep the dirt out. If any ideas please Help so I don"t waste a good D
Thank You
