2240 Hydraulics
MikeV
12-07-2004 05:42:16
I just purchased a JD 2240 and have no previous experience with tractors. It takes a few minutes for the 3 pt hydraulics to work after starting the tractor. When they do work the motion isn't smooth. I purchased some tractor hydraulic fluid as it seemed empty when I looked in the resevoir (I assume the screw on cap under the seat above the 3 pt hitch). How do I know when I've put enough in?
Also, there is some sort of an orange dipstick behind where the right foot rest is. What is that?
When I pull the dipstick out, fluid runs out.
Thanks for any help!
Spoker
12-07-2004 20:01:22
 Re: 2240 Hydraulics in reply to MikeV, 12-07-2004 05:42:16
That dip stick is for the tranny sump. You have over filled the tranny with hyd. oil. Check you hyd. filters and sump screen. then if those do not help you have the hyd. pressures checked at a dealer
Dennis M.
12-08-2004 08:28:14
 Re: 2240 Hydraulics in reply to Spoker, 12-07-2004 20:01:22
I am no expert but have been in your postion before with different tractor. The first thing you need to do is buy a manual on this tractor. Much cheaper in the long run then to screw something up.
