'49 R with NO PTO..???
BushogPapa
12-06-2004 17:25:52
How hard would it be to install a PTO on an "R" that never had one..?? A complete rear-end tear-down..???
How strong are the PTO's in the "R" anyway..???
Thanks...!!!
Ron..
Gpower
12-07-2004 11:04:01
 Re: '49 R with NO PTO..??? in reply to BushogPapa, 12-06-2004 17:25:52
I have everything you need if you are interested.
[email protected]
bud sather
12-07-2004 08:37:17
The PTO's on an R is its weak link. A lot of the times its the beveled gears that are wiped out. Replaced the gears in the tractor I have now because of baleing hay with the R. Cost modest $250 for used ones.
RB70D
12-07-2004 06:55:47
The R has a tendency to twist off PTO shafts when under a heavy load, the shafts were not strong enough for the torque of the diesel. If you make a habit of looking at the PTO shafts on the Rs you will find many of them have a slight twist.
Mike M
12-06-2004 18:48:17
"R"s are know for having weak pto's.
I love these old 2 cyl. tractors but if you want something for heavy or steady pto work look for more cylinders 4 or 6 will suit better. But hook on that drawbar---- those 2 cyl. will put the power to the ground this is where I think they shine.
