Deere 316 pumping oil out of the breather.
Tommy H
12-06-2004 16:40:40
Got a 1988 316 with the 18hp ONAN Twin. Starts and runs. but after a couple minutes running it suddenly starts pumping oil out the breather next to the carb. I dont mean like a oil mist, I mean an oil geiser.
Got new oil, and new filter.
Also, there seems to be alot of air moving out of the breather hose. When I put the cover on the air filter that seals the filter down it dies.
Any ideas?
Stephen Brown
02-08-2006 17:36:02
 Re: Deere 316 pumping oil out of the breather. in reply to Tommy H, 12-06-2004 16:40:40
I have a 1987 JD 316 with B43E onan v twin also. Same exact problem occurred, compression check showed 25% or better reduction, dealership tech suggested blow by, combustion gasses entering crankcase due to worn cylinders and rings. Problem is that an overhaul of a nearly 20 year old engine with very very very expensive parts, is impractical, not to mention labor. What did I do? Went to small engine warehouse and got a 20hp new Honda retrofit engine with new electric clutch, 2 yr. manufacturer warranty, for $1450. If your in the 316 for the long haul consider this investment. Best of luck, my onan is in the back yard on cement blocks, want to buy some parts?, just kidding, I am going to plant flowers on it.
Steve
