1010 moter rebuild
tony weir
12-06-2004 15:07:20
I just rebuilt a moter in a 1010 what is the best way to brake in the moter I know that the 1010 tractor is not one off john deeres better designs why ? I thought the design was pretty good since rebuilding the moter in frame only took me a few days and only cost about $3000.0 in parts and machine shop fees i am used to paying $5-6000.0
for rebuilt forklift moters not includeing labour to re/re.
jdemaris
12-07-2004 06:16:34
 Re: 1010 moter rebuild in reply to tony weir , 12-06-2004 15:07:20
$3000 for an in-frame motor job on a little four cylinder engine seems high to me if you're doing the work yourself. I did my 1010 last year for somewhere around $300, not $3000. The new main and rod bearings cost me $110 but the price would have been lower if it was a later serial number 1010. Mine is the early model. I rebuilt the pistons for a total of $40 including machining and top groove repair shims from Hastings. Gaskets, sleeve o-rings, and piston rings cost $80. I did the head myself and two exhaust valves and a set of valve seals cost me $45. I rebuilt the water pump for $36. Carburetor kit cost me $26. My sleeve deck cleaned up just fine, but I bought a good used one recently for $75. A new one is up around $700 from Deere. If I'd been doing the work for someone else, the labor would have been 20 - 24 hours. I just finished rebuilding the diesel engine in my Allis Chalmers HD4 dozer. It's a 200 cubic inch diesel. New main and rod bearing, new rod pin bushings and resized bottoms. New pistons, sleeves, rings, and pins and engine gasket set, a valve job, and the water pump, and went through the Roosa Master fuel injection pump and also four new fuel injector nozzles. Total cost of $1320. Most expensive part of the whole job was the injectors.
