JD 2550 Hydraulic Problem--the truth comes out
DDK
12-06-2004 13:49:57
After numerous conversations, the subject came up that the transmission pump warning light was on when there was no hydraulics or steering. I belive this means that the 150psi that was supposed to be delivered to the front pump was non-existant. Since the owner had partially drained the oil out of it, I told him to finish draining and pull the never-removed strainer. In the meantime, go ahead and replace the transmission oil filter. Refill with oil, and let"s try the hydraulics again. I believe the transmission pump is located somewhere in or about the clutch. I don"t know exactly how it drives. We have a 2630 that lost its hydraulics when the clutch went out before. I don"t know if this might be a similar problem. Any suggestions would be helpful. Thanks in advance, Dennis
towpop
12-06-2004 17:21:42
 Re: JD 2550 Hydraulic Problem--the truth comes out in reply to DDK, 12-06-2004 13:49:57
if the 2550 is designed the same as a 4450.there is a torsional damper(clutch) mounted to the flywheel.it is under constant pressure by way of tension springs,it does not release unless it is defective.the torsional damper drives the powershift pack in the transmission.the transmission pump is located in the front of the powershift pack.the pump should be turning,anytime the engine is running.the inching pedal(clutch pedal)releases hydraulic pressure in the trans to stop movement.it does not have a typical clutch as in a 4020.if the 2550 will move,even tho it doesnt have steering and hydraulics,i would look at the pump or leaks in the plumbing.if it also will not move,it could be the damper or the pump.
