Hand Clutch Lever Connecting Pin
Greg in MO
12-06-2004 12:55:13
Hey all...
Disassembly continues on my '37 A. Got the rear wheels off this past weekend much to my relief.
I am working on the clutch now, and am trying to remove the hand lever, which is connected by a pin through a casting on the right side. The pin goes through the lever, then the casting with a nut to theoretically hold it together. Got the nut off with no problem. I originally thought this was just a pin that should just slide out, but it isn't sliding. Is the casting threaded and is this "pin" really a bolt that is threaded into the casting? How the heck to I get this thing out (it has a round head like a pin)? I would really like to get this lever off for cleaning/painting.
Thanks!
Greg
John Van Valkenburgh
12-07-2004 04:13:36
 Re: Hand Clutch Lever Connecting Pin in reply to Greg in MO, 12-06-2004 12:55:13
Greg,
Don't hammer on the end of that pin! I used a large 2 ear'd puller on mine. Once I got the pin out I drilled a hole part way down the middle and then another hole in the side. I tapped the hole at the end and fitted a grease fitting.
My pin was still in good shape. I replaced the bushing though.
Best of luck,
John
1953 Model 50
John T
12-06-2004 13:07:15
Greg, slop n wear in BOTH that pin/bolt and lever bushing is typical, I always replace BOTH the lever bushing (which is usually non existent after some years) and a new pin/bolt. They are both available from Mother Deere.
The bolt/pin fits tight into the casting hole as its surface there is sort of knurled/marked and once squeezed/bolted in she holds tighter than Dicks hat band. Its NOT threaded, just squeeze interference fitted in there. BE CAREFUL tryign to drive her out as you dont wanna break off the top of the casting. My ol Missouri buddy Mike (ML) Aylward who posts here makes and sells a puller for pulling those bolt/pins out, but Ive simply used heat n pipe wrenches and punches etc and got them all out with no breakage. BE GENTLE
The easiest method we use to remove those pin/bolts in applications where we can get at it, is to use a flat blunt punch end on a vibrating air hammer and they push right out.
John T
Mike Aylward
12-06-2004 17:00:47
 Re: Hand Clutch Lever Connecting Pin in reply to John T, 12-06-2004 13:07:15
Greg, I have several of the pullers made up. Email me if interested. The email is open. Mike
Robert Rudebeck
12-06-2004 14:52:51
I use the puller made by the buddy. It works great no chance of breaking casting. If you remove lots of these pins the investment is worth it & it's quicker. Robert.
