Extent of rebuild on 49'B ??
Brad49
12-06-2004 09:44:39
Just got a 49"B and its had water in crankcase and transmission. My question is can I get by just pulling the head and reworking it or should I get into the crank, etc. Water is evident under the tappet cover with rust or scale on 2 pushrods and one spring and surface of the head. Thought I would pull head and clean it up and check the valves and if they look ok try not to get any deeper in the engine. I have never rebuilt entire engine, so I am hesitant, also don"t want to invest any more than necessary to get her running again. The tractor is for help around the farm but light duty. What do ya"ll think and what should be inspected to determine appropriate steps to take. Thanks - Brad
Mike M
12-07-2004 06:40:28
 Re: Extent of rebuild on 49'B ?? in reply to Brad49, 12-06-2004 09:44:39
If it isn't stuck I'd try to get it running like it is first to check and see if everything else works before I'd dump a bunch of time and money in it. Take off the top cover of the tranny and engine first and flush out and check for heavy rust if you find any in there you are looking at a complete tear down or part it out.
BushogPapa
12-06-2004 17:35:21
If you don't think it has much rust in the cylinders, I would change the fluids, soak the cylinders with oil, and crank it slowly and carefully---then with the starter and run it...may be that it is ok.. If not..you can tear it down....just maybe you won't need to..!!
Ron..
Brad49
12-06-2004 18:42:04
 Re: Extent of rebuild on 49'B ?? in reply to BushogPapa, 12-06-2004 17:35:21
Ron , I will check the cyl. walls when the head is off. I was thinking of what might be inside of the crankcase..... May be that"s not so important? At any rate I will verify that valves ,springs , seats ,oiling rod is ok , then maybe put back together and run. Going to rebuild the carby also before firing up. Otherwise, will run and fix and rebuild other items as necessary.. THanks for your input. Anybody else had a similar experience????
BushogPapa
12-06-2004 19:25:09
 Re: Extent of rebuild on 49'B ?? in reply to Brad49, 12-06-2004 18:42:04
If I were to remove the head, I would just go ahead and put new rings in it, or bore it if it needs it....2/3rds of the work is done by the time the head is off...!!!! You wouldn't put the head back on without a new valve job... Turn it over and be sure you have oil pressure after you change the fluids... See if the sucker will run...!!! I don't like to do things Twice.....!!!!
Ron..
Brad49
12-07-2004 03:08:55
 Re: Extent of rebuild on 49'B ?? in reply to BushogPapa, 12-06-2004 19:25:09
Hey BushhogP - makes sense to me . Going to the 'place'today and pull head. How hard is it to bore? Maybe I will ... Guess I'll have to seperate the block from the tranny to bore? What should I put on my shopping list? Should the crank be turned too? What about rods? Help... This'l be my first engine rebuild. Thanks for the advise. What to look out for?? Brad
BushogPapa
12-07-2004 06:14:56
 Re: Extent of rebuild on 49'B ?? in reply to Brad49, 12-07-2004 03:08:55
Why are you so sure you need to tear it down..??
If the rod journals are smooth, it is seldom necessary to turn the crank... You can't know what pistons and rings you will need until the block is "cleaned up"..that is: honed, or bored... If you Must tear it down and do all of that, I would bore it +.125 and get higher compression pistons...you only have about 5.6 to 1 compression now..IF it is a Gasoline engine, and about 4.5 to 1 for All-Fuel. 6 to 7 to 1 would be best for power.. Would get you well above 30 horse power.. Get a Good 3-angle valve job...Have the valves polished if you can to help prevent burned valves... The block can be a "hand-full" for one person to remove.. Geting the manifold bolts out can be a real job, too... Use plenty of "anti-seize" when you re-install.. Let us know how you are doing..! Ron..
