2355 fan belt change
cassidy
12-05-2004 17:48:38
I just purchased my first tractor . I need to change the fan belt (no help in the manual . Can anyone share any problems or how to steps? thank you
R. John Johnson
12-05-2004 20:34:29
 Re: 2355 fan belt change in reply to cassidy, 12-05-2004 17:48:38
I don't know if it is the same as a 2755, but see if this makes sense. Look on the front of the engine where the hydraulic pump drive connects. There are 4 bolts holding the cast pump drive to what is a flexible coupler. Remove the bolts and turn either the pump or the engine a quarter turn. You should now be able to wiggle the front portion of the coupler out, followed by the rubber center portion. This should give you enough room to install the fan belt over the crankshaft pulley. Reverse order to reassemble.
If you go to jdparts dot com you can look at the picture in the parts book which should show how this all goes together. Hope this helps
John
