430 distributor
Hayfarmer
12-05-2004 11:24:22
I have an IT manuel but it doesn't really go into distributors at all for this model. I put in new points and condensor and changed front plugs. Retimed with timing light. I had the distributor apart but was bafeled as to how the advance mechanism works. At what rpm should it be in non advance state? When I throttle it back quickly it will back fire at lower rpm.
Henry J
12-05-2004 15:33:41
 Re: 430 distributor in reply to Hayfarmer, 12-05-2004 11:24:22
Hayfarmer
If you had the distributor apart, I assume that you had it out of the tractor and completely torn down. In my small experience, I have found that it necessary to pull the two shafts apart and get the gunge out of there so that when the weights and springs advance the timing all works free.
You can look at/eyeball the curve coming up by watching through the hole with the timing light and after you set it on the mark at fast idle, pull the throttle back and see if she retards freely and vise versa.
good luck and let us know
happy holidays
ChuckW
12-05-2004 14:26:09
In my book the most important item is the springs. I would recommend replacing them as this is most important to achieve full retardation. This is most important for proper starting and advancing.
John T
12-05-2004 12:34:53
Farmer, the spark timing advance mechanism is basically a centrifugal weight advance type of unit. Just sitting there not turning the weights are held back but as it begins to rotate the centrifugal force acts on the weights against the spring tension trying to hold it in, thereby rotating the plate and advancing when she fires. Shes full non advance at zero RPM then advances as RPM increases with the time and amount of advance dependant upon the weights n springs. The spark is advanced by rotation of the plate upon which the points are located since rotating it makes the points open sooner.
This (advance curve, i.e. degrees of advance versus RPM) is not so critical in our low RPM 2 cylinder tractors with low compression and low octane fuels as it is in very high RPM engines with exotic fuels. The advance curve is set (at the factory) for the RPM and compression and fuel and ignition we run, so unless we up the compression and RPM and fuel drastically, I dont advise much jury rigging of it (change weights n springs etc) unless one really knows what they are doing and have a Dyno to measure the effects.
Best wishes n God Bless
John T
Bob
12-05-2004 12:01:53
The distributor will start out at the latest timing, and gradually advance as the engine speed increases.
The rate at which this occurs is called the "advance curve".
If the springs and weights are all original, and not badly worn, clean oil the parts thoroughly, and lightly lube the advance parts with thin motor assembly lithium grease. Oil the wick INSIDE the distributor cam that lubricates the area between the distributor shaft and the cam with light oil. (If someone has changed the weights and/or springs to try to "improve" it, the advance curve may be way off from what is needed, but if everything is original, and in good condition, it should work when cleaned up and lubed.)
Make sure the mechanism is assembled correctly, so the action of the weights moving outward with an increase in speed actually advances the cam.
