70 and 720 steering removal
Mark
02-10-2004 15:46:34
How the heck do you remove the steering wheels to get the hood off of a 70 and a 720. 720 has power steeing, 70 does not. I did a search on this site, but it only came up with older machines.
Thanks
Clooney
02-10-2004 17:25:28
 Re: 70 and 720 steering removal in reply to Mark, 02-10-2004 15:46:34
Mark, on the power-steering tractor... first remove the nose grille assembly, then mark the steering shaft to steering gear sleeve for re-assembly purposes, then remove the safety wire [most are missing], then drive the roll pin out, then remove the seat from the battery box, then pull the steering shaft with the steering wheel still on it out the rear.. Then the hood will come off..
~On the manual steering tractor.. First remove the nose grille assembly,, then remove the steering wheel & shaft key [you will probably need a gear puller],, then remove or loosen the radiator top tank upper baffle,, then remove the bolts holding the steering gear to the top of the pedestal,,then pry the steering gear away from the pedestal,, then pull the steering gear & steering shaft out the front.. When reassembling the gear remember those gear to pedestal gaskets are also shims so the thickness should remain the same.. OR ANOTHER WAY... If you want to you can leave the steering gear on & just unbolt the front worm bearing cap then screw the worn & shaft out the front to remove it.. The shaft will screw out the front then pull all the way through the steering gear... [personally I pull them steering gear & all]
[email protected]
John T
02-10-2004 17:00:05
My 620 had a hollow roll pin through the shaft (where splined shaft fits into collar) plus a safety wire. Removal of those allowed the shaft to be pulled out of the steering box no problem.
John T
70D
02-10-2004 16:04:09
First you have to take the nose cone off and then you will see where the steering shaft hooks to the top of the gear box you will have to remove some kind of pin or bolt there
second you have to remove the top part of the seat you do this by use the seat adjustment lever and taking the seat forward then you should be ready to pull the steering shaft back you might have to put alittle oil on the shaft where it comes through the bushing
I think this is all you need to do if you have any question post back
70D
720Deere
02-10-2004 16:00:45
First take the front section or "nose" off. This will expose the sterring shaft at the steering valve. Should be a roll pin holding it in place. The front hood section has to come off first anyway to remove the hood.
