4010 starter / electrical problems
OTH4010
12-04-2004 15:32:19
I finally got around to putting my rebuilt starter back on my 4010 today. it did have a 12 volt sol on it instead of a 24v. and the feild coil was grounded wich explains the spark when trying to connect the Batt. terminal. My problem now is that it starts to crank when I turn the key to tne the run position. I did not have this problem until I changed the ignition switch trying to correct the previous starter problem. I felt sure I placed all wire back in the right place on the ignition switch but maybe I crossed one. Does any one have a wiring diagram (or where I might find one), or a suggestion on what I might try?
gwece
12-06-2004 06:32:07
 Re: 4010 starter / electrical problems in reply to OTH4010, 12-04-2004 15:32:19
OTH4010: I have a wiring diagram I made from a combination of the ones in the shop manual and a physical comparison to my 4010 Diesel wiring. Send me an email and I will email it to you. [email protected]
gwece
twopop
12-04-2004 17:36:41
dont have the capability to send diagram.if you hold ignition switch and looking at back of switch.black wire at 10 oclock-to light switch
green wire to 2 oclock-to light switch
large black wire to 4 oclock-battery b
blue wire to 9 oclock-battery a
red wire to resistor terminal in center-ignition
yellow wire to 7 oclock- start circuit
txblu
12-05-2004 07:20:32
 Re: 4010 starter / electrical problems in reply to twopop, 12-04-2004 17:36:41
Nice reply. If however, your wiring has been "modified" so that you can't see which wire is which color, use a voltmeter to find which terminal on your switch is hot only when the switch is in the start position. Then hook your solenoid excitation wire to it and go.
Mark
