60 REAR WHEEL ADJUSTMENT
MDM
12-03-2004 16:42:08
WHAT IS THE CORRECT PROCEDURE TO ADJUST THE REAR WHEELS ON A 60, MINE ARE THE "WINDOW" TYPE IF IT MAKES A DIFFERENCE.
BushogPapa
12-04-2004 17:34:16
 Re: 60 REAR WHEEL ADJUSTMENT in reply to MDM, 12-03-2004 16:42:08
This can be a little "lengthy", and I am sure it is addressed in the "Archives".. Basiclly, loosten the 3 Big bolts, jack the wheel up till it just clears the ground, and Tighten up the remaining 2 smaller bolts...they are called "Jack Bolts"..for forcing the wedge to loosten up in the hub... IF (if??) the wedge loostens, you are 1/2 way home...!! Then you need to TRY to turn the Pinion on the side of the hub to move the wheel in or out... ( You DID start Soaking it with oil a Month ago, I hope)..!!! Take the cork out at the other end of the pinion, and let MM oil, or some penetrant soak in the hole. If it won't move..Heat may help.. If you don;t have time to mess with the pinion, thake all 5 bolts out, and let the wedge fall out... Then, you can wrestle the wheel in or out by turning it until the pinion teeth are out of register..it will slip back in the teeth when you turn it back... Have someone push the wedge back in place, and run the bolts back in... I like to grease the outer side of the wedge, when I put them back in..not the whole wedge..just the outer side.. Good Luck, and let us know how it is going...these can be a "piece of cake", or they can be stubborn... Sometimes I have to soak the hub with Marvel Mystery oil, and 10/30, then heat the hub for about 45 minutes with a good old fashioned blow torch to get the wedge to move...then more to get the pinion to move....!!!
Ron..
MDM
12-04-2004 21:50:51
 Re: 60 REAR WHEEL ADJUSTMENT in reply to BushogPapa, 12-04-2004 17:34:16
THANKS FOR YOUR INSTRUCTIONS, HOPEFULLY MINE WILL BE OF THE FORGIVING KIND, LOL
