JD 2020 diesel starter problem
farmall100
12-03-2004 16:17:17
When I turn the key I can hear and feel a clunk in the starter but the starter will not turn the engine. I have to repeatedly switch on/off to ever get the starter to engine. This problem seems to be worst after sitting for several days as opposed to the tractor being stopped for a few minutes or hours. The starter\solenoid assemby was replaced with a new one 12 months ago. Could the solenoid have gone bad or been bad out of the box. thanks for any help
txblu
12-05-2004 07:28:47
 Re: JD 2020 diesel starter problem in reply to farmall100, 12-03-2004 16:17:17
Wild guess. Being it's cold and damp, you have an accumulation of crud in your starter that is aggrivated by the moisture and it sounds like if the other suggestions fail, a removal and thorought cleaning of the starter is in order. This seems to be the case as if you stop and restart the tractor in a short period, it hasn't had time to injest moisture like it will do in sitting.
Remember, if a surface is colder than it's environment, the environmental moisture will condense on (in) it.....glass of iced tea in the summer time....(cold beer).
While in there might just do new brushes and bushings.
I have found that Berryman's (maker of Chemtool spray and liquid) makes a brake cleaner spray(white can with picture of front disc brake on front) available at Auto Zone.
Cheap, has a lot of pressure to push out crud, chemical cleaners that remove grease but don't attack paint like chem tool carb cleaner does.
HTH.
Mark
twopop
12-04-2004 06:42:05
hook up a test light to the starter post,where it enters the starter,and try to start.the light should show power going into the windings.if the light shines brightly, you have a brush or winding problem in the starter.if the light doesnt show power,it may be in the solenoid.bad battery connection may activat the solenoid,but not enough power to turn the starter
twopop
12-04-2004 06:41:11
Gerald J.
12-03-2004 19:20:17
Could be the solenoid, but the first check is to clean the battery posts and the battery cable connections. Take the grounded cable off first and put it back on last. Clean the battery posts and connectors with a wire brush made for that purpose until they are shiny.
Gerald J.
