4620 Steering issue
Ryan
12-03-2004 14:51:43
I bought a 4620 at auction, advertised as having a hydrualic pump problem. The front end has had some peices replaced, such as the peice connecting both tie rod ends for each side of the front end and at least one vertical spindle, so something rather tragic has happened. They said something about the tractor would act fine it you bled the hydraulic pump, and they have installed a small bleed valve there. The 3pt chatters and shakes going up and the steering is sluggish is it is not performing correctly. So, my questions is, could there be something in the steering portion of this tractor, perhaps in the column causing oil to flow through and not build overall system pressure or does it seem likely it is just the pump? I ask this becuase my grandfather once impacted the front of a 5020 and had to do work in the column and that tractor still does not steer for the first couple of minutes of operation. Any ideas of where to start? I hate to pull a pump if it could be in the steering as a result of busting it.
Ryan
msb
12-03-2004 19:52:46
 Re: 4620 Steering issue in reply to Ryan, 12-03-2004 14:51:43
Start by replacing the hydraulic filters and also remove the suction screen in the bottom of the transmission case and look it over for debris.I would cut one of the filters apart and look for metal shavings.Then I would check the operating pressure of the hydraulic pump.Then I would do a flow check on one of the hydraulic outlets.If you don't find the problem,I would proceed with a flow test of the transmission pump.I have on rare occasions seen the transmission pump gasket blow out and cause symptoms like you describe,but before I would go there ,do the easy checks first.Your main pumps sounds like it is starving for oil.Unfortunately there are several other places the problem could be in.
Maybe Bob or David Val will chime in.They both are good sources of help.
