1937 AR Engine Question?
Novice KC
12-03-2004 14:25:24
I have a 1937 AR with a serial number 254,000. I was going to pull the piston (think the rings are lined up). When I pulled the head I noticed there was a small sleeve held in place with a set screw at the top of each of the cylinders. I've never seen anything like this..anyone? If so, how do I remove it (pressed in?)? I need to figure this out because, as you can imagine, the pistons will not come out the top with these in the way. Just wanted to get some advice on how to remove them and figure out their intent.
MDM
12-03-2004 16:46:08
 Re: 1937 AR Engine Question? in reply to Novice KC, 12-03-2004 14:25:24
SURE SOUNDS LIKE YOU HAVE COMPRESSION INSERTS, NEVER HAVE SEEN ANY WITH A SET SCREW. MOST WERE HELD IN BY THE HEAD AND HAD A PLACE MACHINED OUT WHERE THE PLUG COMES INTO THE BLOCK, THIS WAS TO MAKE SURE THEY DID NOT MOVE. A NICE FIND FOR YOU!
Mike M
12-03-2004 16:24:42
It sounds like those compression raiseing inserts I have heard about but I have never seen any. Try to get that setscrew out then try to pull out that insert.More than likely it is going to be held in with alot of carbon/rust also. After getting the set screw out (heat may be required )if your pistons move freely I would try to place a block of wood in there and use the pistons to try to bump them out going easy watch and see if they move before getting too rough with them.
