404 in a 4030
JDBert
12-03-2004 14:16:46
Will a 404 bolt into a 4030? What rear wheel casting did they use for 38" rubber? How big of a axle do they have and are there any other tractors you could use the rear 38" casting off of?
JDBert
12-04-2004 14:01:08
 Re: 404 in a 4030 in reply to JDBert, 12-03-2004 14:16:46
Reason I asked is that I need a different loader tractor. I was thinking about a 4030 with a bad motor and 42" rears. I dont want the 329, and was just wondering if the 404 was a bolt in or not. Thanks for all the advice, I guess I'll just have to look for a cabless 4230.
CNJ152
12-04-2004 06:00:28
do you need engine for 4030, I have a 329 I would trade for a 404.
Neil
WTW
12-03-2004 15:10:53
JDB, 4030 38" wheel castings are the same as allot of two cylinders used. It is marked F1500R. Very early 4030 like mine had 2.875 axle diameter all the later and most 4030's have a 3.125 axle shaft diameter. The 3010, 3020 and 4000 use 3.125 outer end axles diameter as well as many two cylinders. So there is tons of wheels out there. I got two off my 4030 and a lighter set of cast as found on early model 60 tractor that I would sell either or both sets. The light set is sandblasted and painted up like new. A 404 engine could be put in a 4030, to do so you would want to use the frame rails and hood from a 4230 as the length of the Waterloo engine is little longer than the Dubuque engine. It also would require a different hydraulic pump bracket as that is one of the major part differences to make it happen. The hydraulic pump, steering motor and front axle are the same parts on both models. The only other hassle would be all your steering and hydraulic lines would have to be alter for length or changed (about 3 inches). Basically what you would have when all said and done is a 4230 front on a 4030 rear. If you wanted to use the 4230 complete front including radiator and fuel tank the cab / fender deck will have to be raised one inch as that is the difference in height of two tractors as well as side panels and side screens. Gets kind of involved as I am studying on doing just the opposite. Putting a 4430 rear end under my 4030 puller for more integrity. Good Luck Study Your Lesson, DW
msb
12-03-2004 20:04:04
 Re: 404 in a 4030 in reply to WTW, 12-03-2004 15:10:53
Simplest solution would be trade it for a larger tractor if you need the extra power.In my opinion, you have a much finer designed engine in the tractor now that the one you are contemplating changing to.
Have you considered who you will sell such a "creation" to in the future?I have a neighbor who went to great lengths and a spent a lot of money to install a 903 Cummins in an Allis D21.He recently had it hauled off to the junk yard because no one would buy it.Of course the transmission was shot.The transmission wasn't designed for that much power and neither is your 4030.Been setting in his back yard for years and years.
merf
12-04-2004 13:42:39
 Re: 404 in a 4030 in reply to msb, 12-03-2004 20:04:04
I appreciated your advise on changing motors. I have been thinking of doing something similar and will give it considerable more thought after reading your words of caution. Thanks Merf
The whole picture
12-04-2004 07:50:28
msb, I do agree the guy should have not attempted the D-21, he should have just hauled it to the Junk Yard before he started, but hey it a free world. Fact is when people alter tractors for pulling or any other reason to achieve certain things they could care less what you or the next guy thinks. If he is building a pulling tractor he is not planning on reselling it for market value anyway. Last I knew we still lived in a free country to do what ever one wants within the law. I don't think building pulling tractors or any other creation that there is a law against it. So go dry your eyes and GET OVER IT!!
msb
12-04-2004 08:27:48
 the whole picture in reply to The whole picture, 12-04-2004 07:50:28
Not crying here.Nothing to get over either.Just trying to keep the guy from building another piece of junk.If its going to be a puller,thats one thing.If he plans on using if for farming that is quite another.And for the rcord, I have done my share and more, of modifying tractors.Now why don't you try lightening up.I only had his best interest at heart.I don't think that was wrong.
