Tex, those systems can indeed be a lil tricky to troubleshoot, I will lay some theory on you concering how they use BOTH 12 volts for lighting and 24 volts for starting and charging which may or may not help you. 1) The 24 volts is from the two 12 volt batteries connected in series. Thats for the 2 wire ISOLATED FROM FRAME GROUND starter and Generator. Unlike their 12 volt counterparts, none of their field windings nor armature brushes are in contact with thier cases (frame ground). 2) In order to get only 12 volts for the lights, where the two batteries tie in the middle (the inner series connection) they also are tied to the frame ground. Therefore, the voltage between either batteries outermost untied post (one is + other -) to ground is 12 volts, while its still 24 across both of them. 3) Those 2 outermost + and - 24 volt posts are what feeds 24 volts to the starter plus where the charging system works charging the batteries in series. ALSO, smaller wiring from each outermost untied post goes to the light switch, one is labeled A and the other B. The light loads are approximately balanced with the 12 volt A circuit feeding some lights and the other B the remaining ones, as, remember, from either of those points to ground its 12 volts. 4) If youre not reading 12 volts up on the switches A and B input terminals, its either cuz where the 2 batteries are tied in the middle theres no connection leading to frame ground,,,,, ,,,,or theres wires missing from the batteries outermost untied posts up to the A and B switch terminals. YOU GOTTA HAVE BOTH the centers tied to frame PLUS the A and B 12 volt feeds up to the switch for 12 volt frame grounded lights to work. 5) Consider the entire 2 battery system as two circuits. The 24 volt circuit from the 2 outermost untied posts feeds the starter and generator,,,,, , while those same 2 posts feeds the A and B (12 volts from either to ground) 12 volt light circuits vis the switch. The trouble is, even if one understands how they work, all them dern wires makres it tough to figure out whats what. Dave aka WTW is darn good on those 24 volt systems and Im tryin to talk my old buddy Glen aka buickndeere to give a seminar on them at the next GOG (I been avoiding those 24 volt issues like the plague lol) so maybe they can add to this and the other good advice posted below. Good Luck n God Bless John T in Indiana
