4020 front crank pulley
Curt
02-10-2004 13:57:25
Does the front crank pulley act as a balancer on a 4020. Is there any trick to changing a front crank pulley. And a front crank seal while I'm at it.
Curt
02-10-2004 18:01:53
 Re: 4020 front crank pulley in reply to Curt, 02-10-2004 13:57:25
Yes it is a diesel. Can this be done without removing the radiator
zane
02-10-2004 18:53:15
 Re: Re: 4020 front crank pulley in reply to Curt, 02-10-2004 18:01:53
Yes. You don't have to remove the radiator. It's tight, but it's a lot less trouble than removing the radiator.
WTW
02-10-2004 14:12:39
On a 4020 Diesel the front pulley is an harmonic balancer. A gas is just a pulley. It is a straight press fit and can be pulled off just like you would a small block Chevy after removing the 5/8" bolt in the center of it. The front seal is trapped behind a lip on the timing cover and to replace it you will have to remove the timing cover which also is connected to the oil pan which will lead to replacing the pan gasket also. Good Luck, Dave W.
