can you put a 540 shaft into a 4620?
PJB
12-02-2004 09:42:57
I know where I can buy a good 4620 cheap ,but it does not have a 540 shaft. Does anyone know if Deere made a 540 shaft for a 4620?
4620
12-02-2004 17:08:22
 Convert your spreader to 1000 rpm! in reply to PJB, 12-02-2004 09:42:57
As mentioned by previous poster.
infogatherer
12-02-2004 14:30:08
 Re: can you put a 540 shaft into a 4620? in reply to PJB, 12-02-2004 09:42:57
A 4620 was too much power for a 540 shaft in those days. They didnt have the resourceses to make it work good. Today its different
fredy
12-02-2004 10:08:08
Hub city makes an adapter gear box i dont know what it cost but it could be worth it.Whatever john deere engineer come up with the single speed shaft should have been fired
G/MAN
12-02-2004 10:36:58
 Re: can you put a 540 shaft into a 4620? in reply to fredy, 12-02-2004 10:08:08
Mike M. is correct. It wasn't planned that a tractor that size would ever be used for tasks like running augers or baling hay, when there were smaller, handier and much more fuel-efficient models in the Deere line to handle those jobs well. Successive "big" tractors in the Deere row-crop line were and are also 1000-only, such as the 4630, 4840, etc. The 8000s can be equipped with a 540/1000 optional set-up, but why anyone would want a 165 on up to 225 hp tractor wasting it's time on a 540 shaft is beyond me.
PJB
12-02-2004 11:54:02
 Re: can you put a 540 shaft into a 4620? in reply to G/MAN, 12-02-2004 10:36:58
I thought the 4620 was only 135 HP ??? I have a real big spreader that is 540 RPM.
G/MAN
12-02-2004 13:44:17
 Re: can you put a 540 shaft into a 4620? in reply to PJB, 12-02-2004 11:54:02
You have to put that "only 135 hp" in the context of the time period. That was a BIG row-crop tractor in those days. 1000 rpm PTO-driven equipment requiring 135-hp wasn't too common in those days, let alone big 540 rpm iron. And then when the 40-series came out, the 4640 and 4840 went to the large 1000 shafts.
buickanddeere
12-02-2004 12:31:47
If the main drive is a chain, just reverse or replace the sprockets. Some equipment converts from 540 to 1000 just by unbolting and turning over the main gearbox. Then just replace the input shaft with a 1000rpm unit.
Mike M
12-02-2004 10:27:27
540 rpm is not very well suited to take that kind of horsepower.
Indydirtfarmer
12-02-2004 09:59:35
It's more than just the shaft. If you could switch shafts to a course splined 540 shaft, it would still turn 1000RPM.
