730 Questions
Tonys Antique T
12-02-2004 07:56:59
I have a 730 Diesel which I believe has a taper lock flywheel on it. I need to take up some crankshaft end play and wanted to know the proper way to do that with this flywheel. Also, I fried my wires in my distributor the other day when running it. Does the red dash light indicate that the tractor's pony motor has juice? If so, should the red light be on when the switch is in the LIGHTS position. After you start the tractor, are you supposed to put the switch to OFF? Any answers would be great. Also, when I disengage my clutch, I get a clanking noise. It doesnt do it when I engage my clutch? What is this, it is not the flywheel because that is all tight.
Thanks for any help.
Tony Ohmes
F-I-T
12-02-2004 08:40:27
 Re: 730 Questions in reply to Tonys Antique Tractors, 12-02-2004 07:56:59
Tony:
After you start the diesel, move the switch to either Off or to Lights. Either will kill the power to the pony distributor.
See below for the flywheel adjustinment.
When you disengage the clutch, there is all manner of disks and plates that are now free to rattle, and this is prefectly natural. Once you have one apart and see how many separate pieces of cast iron and linings are availalbe to jingle, you'll wonder how they stay so quiet.
Frank
