2240 Information
Dennis M. Annea
12-02-2004 07:08:37
I found an ad for a JD 2240 with a 145 loader. Can anyone point me in the right direction to get some specs on this unit. HP? Lifting capability (weight capacity)of the 3 pt hitch and lifting capability (weight limit) of loader.
Indydirtfarmer
12-02-2004 13:46:03
 Re: 2240 Information in reply to Dennis M. Annear, 12-02-2004 07:08:37
OK! I made it home intact one more time. (Traffic is WILD around here.)
Here is the specs on a John Deere 2240;
50 HP measured at the PTO at 2500RPM. 3 cylinder diesel. operating range of 1500 to 2500 RPM. 4.19" bore x 4.33" stroke 16.2/1 compression ratio. 179 cu. in. displacement16.5 gallon fuel capacity. PTO 540 RPM LIVE standard, with 540 RPM Independent (hydraulically controlled) optional 8 speed transmission (4 reverse) hi-lo shift (hydraulic) optional. Hydraulically actuated brakes, cooled in oil. 12 volt charging and lighting system closed center hydraulics with one or two remotes available. shipping wieght (approx. 4255lbs) Standard tires are 6.00x16 front and 13.6 x 28 rears. Hope this helps. John
Dennis M.
12-02-2004 17:17:12
 Re: 2240 Information in reply to Indydirtfarmer, 12-02-2004 13:46:03
Thanks John. Now all I need to do is convince the wife.
Pete/ME
12-03-2004 05:06:38
 Re: 2240 Information in reply to Dennis M., 12-02-2004 17:17:12
Bought mine with same loader and hi-lo about five years ago with 800 hrs. for $10k. One of the smarter things I've done. Perfect size for a chore tractor, the loader will lift the materials bucket filled with wet sand, plenty of power. By-passed the scv's with direct lines to pump and sump to use a Valby 150 chipper/powerfeed and it works fine. The tractor is small enough to get around, and strong enough to do what I need. I've put about a thousand hrs. on it with no problems.
Indydirtfarmer
12-02-2004 08:17:33
When I get home, I'll get out my books on that tractor and post my findings. I don't have much on the loader though. John
