3010 Clutch ware
GRR
12-02-2004 06:43:59
I bought a 3010 D about 2 years ago and have put @ 350 hrs on it mostly haying and hauling bales.
I adjusted the clutch three times and now am installing a new one.
Question how many hrs is normal on a clutch with this model?
GRR
12-03-2004 06:50:30
 Re: 3010 Clutch ware in reply to GRR, 12-02-2004 06:43:59
Cluth was not new when purchased, had and has a loader on it. The adjustment, free play, was 3/4 used up and 1 made 3 more adjustments until I ran out and I am now putting in a new clutch.
G/MAN
12-02-2004 13:49:17
Did it have a new clutch in it when you purchased it? Clutch life varies greatly by how and how often the clutch is used, and what quality of parts are used.
idontno
12-02-2004 07:11:11
GRR.....Get UR foot off the clutch.Sounds like you are Riding it or you are slipping it too much.I have a 4020 that has 7,000 hrs and still have the original clutch.I don"t think it has ever been adjusted....idontno
thurlow
12-02-2004 08:29:48
 Re: 3010 Clutch ware in reply to idontno, 12-02-2004 07:11:11
You're right; all depends on how it's used. With a loader (a lot of back and forth), you might only get 3000 hrs. For field work and with it properly adjusted, they'll last a looooo ooong time.
GRR
12-02-2004 09:58:21
 Re: 3010 Clutch ware in reply to thurlow, 12-02-2004 08:29:48
Thanks, I do use the loder to move bales etc. @ 1/2 the time.
Mike M
12-02-2004 10:43:06
 Re: 3010 Clutch ware in reply to GRR, 12-02-2004 09:58:21
You say your clutch is only 2 yrs old ? Did you put in an organic lining ? For loader use I would put in a metallic or ceramic or even a kevlar lining this would all depend on how you used it as some get aggressive.
G/MAN
12-02-2004 13:47:54
 Re: 3010 Clutch ware in reply to Mike M, 12-02-2004 10:43:06
The metallic/ceramic disks are the LAST ones you want to put in a tractor used for loader work a lot. The disks hold up fine, but the flywheel and pressure plate wear out quickly when you're engaging and disengaging the clutch dozens of times per day. Disks are a lot cheaper to replace than the iron parts, so organic is the only way to go for loader tractors. The way I understand it he bought the tractor 2 years ago and has put 350 hours on it. It doesn't say if it was new when he bought the tractor or not, so it could have had a couple thousand hours on the clutch prior to him purchasing it.
