JD 2140 value?
Bobc3
12-01-2004 18:45:41
I have the opportunity to purchase what I am told is a JD 2140, 1978 model, 4 cyl diesel, 55hp. Type - 4276DR01, ser. - 340859T.
It has a loader that is currently not mounted (right mount point is broken - cast iron broken around mounting holes on engine plock at rear - brake pedals also broken off as they mount at this same location). Also, hi-lo shift lever is broken (you can actually pull it out of the socket). Engine supposedly runs good (have not witnessed). Is set up with remote hydraulics (two ports in rear as well as manifold to run "bat-wing" type mower). This unit has been used commercially to mow right-of-ways most recently - not sure of history before then, nor am I aware of actual number of hours on the tractor.
I am considering offering $2,000 as is for this tractor, and maybe $3,000 if seller repairs current known damage (loader, brake pedals, etc.). However, I am not sure the cast iron can be welded strong enough to handle the loader again.
It does have PTO and a three-point hitch with most parts.
Does this sound like a fair offer (from a buyer"s perspective)?
I have a few photos if that would help anyone give an opinion - e-mail me and I will send to you.
Thanks for any help!
Bob C.
Indydirtfarmer
12-02-2004 03:03:06
 Re: JD 2140 value? in reply to Bobc3, 12-01-2004 18:45:41
Sounds to me like this tractor has led a rough life. First off, (I do commercial mowing) pulling a batwing mower fulltime is a very abusive environment. Look for wear on the PTO clutch/brake. I doubt that the loader mount can be welded to regain its original strenght. It MIGHT hold for light duty use, but don't look for it to be as strong as it once was. Having a loader mounted on a tractor can, and usually is abusive to a tractor also. They're rough on front ends, traction clutch, and the driveline in general. The price you quoted is relatively low for that tractor. That should allow you to do some repairs without over-reaching its maximum value.
HOWEVER...Even if you can weld the "loader mounts", a tractor that has been welded on like that will suffer a huge hit on its worth when you go to sell it. Most people will walk away from it when they see that kind of repair.
Finally, what kind of loader is it? A good John Deere loader, say a model 146, will add quite a bit to its worth. You could expect to pay more than you're offering for the entire rig, just for a good loader. JMHO. John
Dennis M.
12-02-2004 07:14:47
 Re: JD 2140 value? in reply to Indydirtfarmer, 12-02-2004 03:03:06
I purchased a 71 Ford 4000 w/ a Motrim over the rail type mower for less than 2000.00. This unit was used commercially. I have done nothing but replace parts for the last year. Good luck.
Bobc3
12-02-2004 19:50:36
 Re: JD 2140 value? in reply to Dennis M., 12-02-2004 07:14:47
Thanks for the info...gave me a few more things to think about.
If I do make an offer, I"ll keep it low and probably not go over $3000 as is.
