Cracked Front Support on 40
JD40
02-10-2004 11:52:12
I have a small crack on the rear of the front support on my 40, It has been welded before and the crack is small. Should I weld it again or replace the front support
Henry J
02-11-2004 05:43:27
 Re: Cracked Front Support on 40 in reply to JD40, 02-10-2004 11:52:12
40
I always do what Mike suggested. I have been amazed at what this local man can weld up and it never breaks where he has welded. Maybe it is the 40+ years of doing it.
buickanddeere
02-10-2004 16:51:56
Which 40 chassis and which casting? On our 40T with the adjustable wide front it's suffered the classic bust too. Casting #M 1392 T which is subed to # one M4156T and two M4158T has been busted. It's been welded and re-inforced with a formed rod and is an almost respectable looking and quality welded "farmer fix". Stiener Tractor parts in Michigan has numerous reproduction castings incluiding #JDS084 which is JD part #4156T. Going to order one sometime to have on the parts shelf. The current fix does add character and is an exhibit of quality workmanship.
JD40
02-10-2004 16:59:41
 Re: Re: Cracked Front Support on 40 in reply to buickanddeere, 02-10-2004 16:51:56
It is a 40S with a wide front. I don't have the parts manual yet, but it is the one piece front support. I think I will try a welder and see how it holds
tks
MIKE HANLEY
02-10-2004 16:38:20
When it comes to welding, I have a welder but I'm not a welder. When it comes to welding castings,,, that stuff I take to my brother-in-law who is cerified to weld stainless and welds for a living. He also has a small repair shop. He has welded casting for me and they have held. I know my limits. The hardest thing to do to keep old stuff running is to find a GOOD machine shop and a GOOD welding shop. I'd try it again by a welder that welds for a living.
