JD 50 grabby clutch
PJB
12-01-2004 15:21:45
We have a JD 50 and the clutch is real grabby. You have to be carefull when you back up because it sometimes lundges you back fast. We have had the dealership that we bought it from work on it..... they put a new drum in it and springs behind the nuts where you take the clutch up ,and it's still jerky. Don't take me wrong there work helped it ,but it's not as smooth as our 1945 JD B. Does anyone have any ideas where I should start next????? Thanks. Pete
John Van Valkenburgh
12-03-2004 00:29:49
 Re: JD 50 grabby clutch in reply to PJB, 12-01-2004 15:21:45
I've heard that the clutch on the 50 can be pretty "grabby". It may have something to do with the lighter weight of the machine. Make sure that your clutch is properly adjusted with equal tension on the 3 slotted adjuster nuts.
You got a lot of good responses that suggest areas to check for worn componets. I've always heard that oil or grease can make a clutch grabby especially if the contamination is only in a limited area of the disk(s).
I'd think if the Toggles and Dogs have grooves worn in them they may not operate smoothly and cause this problem also.
If adjusting the clutch does not help, you will end up taking it apart to look for worn componets. If you do this, take care when pulling the "fixed" disk. I broke a tooth on mine and I was lucky. Some guys end up with completely busted disk and I'm told these are hard to find.
Before rebuilding my clutch had "spells" where it was grabby. Depended on if the machine was hot and what gear I was in. Turns out my machine was missing 1/2 of the floating disk material. It operates nice and chrisp now, bordering on being grabby but its controllable. When it engages, it means business.
Best of luck,
John
1953 Model 50
BushogPapa
12-01-2004 19:03:39
I have heard "Clooney" write about "concave washers" available from JD to help with this....
I have a 520 that tends to grab..or did...I opened it up, and sprayed an "X" on each side of each friction plate--with spray-on Graphite paint...!!! It soaked in, so I know it is there to stay..!! It hasent grabbed since then...and it doesent slip either..
PJB
12-01-2004 19:47:49
 Re: JD 50 grabby clutch in reply to BushogPapa, 12-01-2004 19:03:39
I will have to try that..... . Where did you buy the Graphite paint?? any hardware store?? Is there a brand that's better..... Thanks for the help. Pete
BushogPapa
12-01-2004 20:02:01
 Re: JD 50 grabby clutch in reply to PJB, 12-01-2004 19:47:49
I got mine at "TSC" I got a Gallon of it, and a couple spray cans, too.!!
The spray cans are handy...I use it on my 3-point parts, etc..
This really did make a difference in the clutch on the 520..it is "sensitive", yet not grabby like it was.. I move dirt and mud with a 7 foot 3-point blade and spin those tires a lot... I have 15.5x38 new tires on 14" rims, 1/2 loaded, and I can't make the clutch slip, so I am real happy with the results..!! It doesent attract dirt and is not a mess to work around...NOW, if I could find Molly in a spray can....!!
Jim Nauert
12-02-2004 02:40:32
 Re: JD 50 grabby clutch in reply to BushogPapa, 12-01-2004 20:02:01
I have seen moly in spray cans in shooting supply catalogs they use it to spray on bullets before reloading.
Tom C.
12-01-2004 18:20:03
My 50 was grabing and it drove me nuts I could not find the problem until I found a real fine hair line crack in the sliding drive disk. My two cents. Tom
PJB
12-01-2004 19:44:53
 Re: JD 50 grabby clutch in reply to Tom C., 12-01-2004 18:20:03
I will check that out..... Thanks for the idea.
Mike M
12-01-2004 16:56:46
I also had a 50 with a grabby clutch I never could get all of it out of it. I swapped out many parts from other parts tractors all look ok none really helped. My uncle told me that way back when the old JD dealer used to throw a hand full of powered graphite in the clutch. I tried this also but I didn't put that much in it may of helped some I'm not sure. I learned to live with it.I could run it pretty good but others had a real problem with it. If you find a definite solution please post back as I would like to know what it was.
PJB
12-01-2004 17:18:35
 Re: JD 50 grabby clutch in reply to Mike M, 12-01-2004 16:56:46
Maybe it's just a flaw of the 50's..... It sure drives me nuts when I'm back up to the hay rake!!!!
Mike M
12-01-2004 19:15:14
 Re: JD 50 grabby clutch in reply to PJB, 12-01-2004 17:18:35
It's not really that different than the late B.
Some of the part numbers are different like the driving disk,but I even put B parts in mine with no noticeable change.
nb
12-01-2004 16:32:48
Check the pins that the linings slide on. They can get a groove in them from normal wear. Unless they were already replaced with the drum.
ChuckW
12-01-2004 15:45:13
to get the grab out you'll probably have to deal in high dollar parts. Sounds like the spline on the disc driver where the floating disk works is highly worn and the floating dish spline is worn. You may also have a bad bearing and possibly the 2 faced disk plate is bad. You could easily spend a$200 to correct the problem. Good luck.
BillS
12-01-2004 22:05:57
 Re: JD 50 grabby clutch in reply to ChuckW, 12-01-2004 15:45:13
I have two 50s and they both have grabby clutches. I was told it was the nature of the beast and learn to live with it which I did.
PJB
12-02-2004 04:40:42
 Re: JD 50 grabby clutch in reply to BillS, 12-01-2004 22:05:57
A old timer told me that the reason the clutch's are grabby on the 50's is because they have live PTO. I don't know if there's any truth to that.
gathje
12-02-2004 09:17:32
 Re: JD 50 grabby clutch in reply to PJB, 12-02-2004 04:40:42
Not trying to be smart .Just trying to help but my 50 clutch is not graby.I did replace all the clutch plates so everything got taken apart and lubed.Just don~t do what I did and bust the fixed drive disk .Not only expensive but almost can`t find one.My 50 does not have live pto.Works real good though. Best of luck.
