60 head bolts
gathje
12-01-2004 14:35:22
Why does it seem the head bolts ,even brand new ones,that you get from John Deere are too short.If you put them in all the way into the block you strip out the threads in the nuts cause the stud does not come to the top of the nuts.Hate to not put them all the way into block and loose pull out strength?
BushogPapa
12-01-2004 19:11:19
 Re: 60 head bolts in reply to gathje, 12-01-2004 14:35:22
On my 630, one end had more threads than the other.... The end with the shorter length of threads went into the block...Then, they went in to the last thread...
Mike M
12-01-2004 16:59:56
Are they shorter than your original ones you took out ? May have to shave some more off the head ?
gathje
12-01-2004 17:46:26
 Re: 60 head bolts in reply to Mike M, 12-01-2004 16:59:56
Same as origonals .I thought maybe some one had replaced origonals with wrong ones.These were what was supposed to go in using my serial number.You would think they would be made to put all the thread in the block.Also you would think they should be for a standard thickness head. thanks gathje
Mike Aylward
12-02-2004 11:58:08
 Re: 60 head bolts in reply to gathje, 12-01-2004 17:46:26
Gathje, you may already know this, but did you put the correct end of the studs in your block? One end has an interference fit that will not screw into the block easily. One end is flat and one is round and you insert the flat end in the block. I was just wondering if you put the round end in and it went in too far. Mike
gathje
12-03-2004 11:07:40
 Re: 60 head bolts in reply to Mike Aylward, 12-02-2004 11:58:08
Thans mike wondering about getting wrong end in block now I know.
Mike M
12-01-2004 19:25:44
I seem to recall a problem like this before on some model JD. The studs when installed with the proper end in the block and tightened up still went in all the way (no threads showed)and this didn't leave enough for the nuts to have full thread. I think I used some locktite made for studs and didn't screw them clear in leaving some threads out so I had enough up top. I think maybe some were tight when not in all the way also.
buickanddeere
12-01-2004 18:59:13
You only thread the stud into the block deep enough so 100% thread engagment is still had by the nut. Are these the tapered Deere studs or brand X studs? Premium hardened nuts and washers are required or the nuts just strip. The hardened washers reduce galling and help keep torque readings vs thrust pressure constant among all studs.
gathje
12-02-2004 04:56:59
 Re: 60 head bolts in reply to buickanddeere, 12-01-2004 18:59:13
Appreciate replies from Mike and Buickandeere.I understand only go into block as mch as needed I still have full threads on nut.Now I don`t understand about the washers .The washers JOHN DEERE uses are lead not hard washers.The studs are the real John Deere thing out of parts book called for by my ser number. Thank you martin gathje
buickanddeere
12-02-2004 12:49:53
 Re: 60 head bolts in reply to gathje, 12-02-2004 04:56:59
The lead will seal the water from coming up around the studs. And the lead is soft enough to act as a lubricant while torquing. I somehow got thinking we were torquing down a flywheel instead, as the data is similar.
