4020 no bat charge
dieselade
12-01-2004 04:14:04
i have to use a jump wire to get the alternator to charge.that is a wire from the main heavy wire on the alternator to the smaller post. the alternator is in fine working order , so could this be the regulater???it is 12 volt tractor,,,two six volt bateries.the alternator was taken to a repair shop and tested ok.
Hoosier JD
12-01-2004 15:38:57
 Re: 4020 no bat charge in reply to dieselade, 12-01-2004 04:14:04
Sorry..... .forgot to say that I have changed my 4010 from positive ground to negative ground. I assumed that yours had been done since you have an alternator. Mike
Hoosier JD
12-01-2004 15:35:15
On a 10SI Delco. The #1 terminal is marked with a "1" on the case... it is in series to the warning light, then to a switched voltage source. The #2 terminal is marked with a "2" on the case...it can be wired directly to the wire that ends-up at the battery. Twopop is right, if the idiot light is burnt-out, it stops the current and will not let the alternator start charging. I messed with this on my 4010 until it became so simple I almost had to get it right! Once I had the light working and all the connections tight, it started charging at 14.1 to 14.3 volts...I was a happy camper! Good Luck, Mike
twopop
12-01-2004 06:12:22
if the light on the dash is burnt out,the alternator wont charge
dieselade
12-03-2004 04:12:02
 Re: 4020 no bat charge in reply to twopop, 12-01-2004 06:12:22
dash light is working
