3020 vs 4030
Ed in IN
10-23-2003 16:31:19
How do these two compare? I would think the side console would be an advantage. What about length of service? The 4030 is a '72 diesel with 5100 hours, a synchro transmission, 540 PTO only, dual outlets, weights, good tires and 4 post ROPS. I haven't talked to the last owner yet. Square baling hay and clipping pasture would be the main uses. The archives were helpful, but was still curious. I want to upgrade from my '65 2020 gas with a 145 loader and get a bigger bushhog so it doesn't take so long to cover 77 acres. Thanks
RJ-AZ
10-23-2003 17:24:32
 Re: 3020 vs 4030 in reply to Ed in IN, 10-23-2003 16:31:19
Ed that 4030 is a lot more horse than the 3020 and a whole lot more than a 2020 gasser. And I am sure that tractor has the 540/1000 PTO, you gotta know how to swap the stub shaft around for the PTO speed you want. It is almost as nimble as a 3020 and with weights and good rubber is still worth a piece of change.
G-MAN
10-23-2003 17:01:07
I would say that the 4030 is going to be the more comfortable and powerful of the two. It will definitely be smoother, with it's six-cylinder engine compared to the four-banger of the 3020, particularly when baling hay. 5100 hours is pretty low for a '72, so it should have a lot of good hours left in it, if it's had proper care. The four-post ROPS is a definite safety and comfort advantage over an open-station. I am a little curious about the PTO. Are you sure it's 540 only? I'm not a 4030 expert, but EPC doesn't show a 540-only version, just the interchangeable set-up found on just about all JD Waterloo tractors of that vintage. I'm not saying that you're wrong, but I am curious. I'd also say that you're probably going to have to give more money for the 4030, but in my humble opinion, you're also getting quite a bit more tractor. And yes, the side console is much easier on the operator than the on-dash levers of an early 3020. If the 3020 is also a synchro tractor, the transmission issue is a wash, other than the fact that the console shifter on the 4030 will once again be handier. With good tires, two hydraulics and weights, I'd say it sounds like a pretty nice unit and would be well-suited to your purposes.
Ed in IN
10-23-2003 17:49:48
 Re: Re: 3020 vs 4030 in reply to G-MAN, 10-23-2003 17:01:07
I guess I should have said it only has the 540 rpm shaft with it. There is a flat cover where the 1000 rpm shaft is kept until needed to swap. Sorry for the incorrect information. Thanks for your input.
G-MAN
10-23-2003 18:08:08
 Re: Re: Re: 3020 vs 4030 in reply to Ed in IN, 10-23-2003 17:49:48
I'm not trying to nitpick or anything, so don't take it that way, but I think what you're seeing is the flat flange where the PTO shaft shield is stored when it's not over the shaft. If that's the case, I'm betting that it has two or three little pegs on it, and some springs to hold the cover in place. Most covers were long ago tossed aside, so it's not big deal if it's not there. The actual 1000-rpm shaft should be sticking out of the rear-end case, above and to the left of where the PTO comes out the back. It should be slid in a bore there, and is held in by a spring-loaded latch. When swapping shafts, you remove the snap-ring around the shaft being used (it can be removed with pliers), slide the in-use shaft out, slide in the other shaft, and reinstall the snap-ring. It's not a dry socket, so some oil will be lost, although it can be minimized by parking the tractor on a hill facing down. Maybe the 1000-shaft isn't in the bore where it's supposed to be. No big deal, as they are available new or used, if it's MIA. I just wanted you to know what to look for and to know if anything is missing if you start dealing on this tractor.
WTW
10-23-2003 21:03:55
 Re: Re: Re: Re: 3020 vs 4030 in reply to G-MAN, 10-23-2003 18:08:08
The 4030 can be used with the 1000 RPM PTO shaft just like the 4230 and 4430. The 4030 tractor was not shipped with the 1000 RPM shaft and the storage hole / spot has a soft plug in it. Get a shaft and remove the soft plug and every thing will fit and work just like the larger models. I have had the 1000 PTO shaft in my 4030 and it will work. Good Luck DW
G-MAN
10-24-2003 05:49:14
 Re: Re: Re: Re: Re: 3020 vs 4030 in reply to WTW, 10-23-2003 21:03:55
Thanks for the info, WTW. I don't think I've ever been around a 4030, so I didn't know that. I wonder why they did it that way? The EPC pictures show both shafts.
Fred G
10-24-2003 06:38:27
 Re: Re: Re: Re: Re: Re: 3020 vs 4030 in reply to G-MAN, 10-24-2003 05:49:14
My guess is that in the early 70's most PTO equipment for sub-80HP tractors was 540 RPM. Deere didn't see a need to provide the shaft figuring most guys with 1000RPM PTO equipment also had another tractor bigger than the 4030.
G-MAN
10-24-2003 07:48:53
 Re: Re: Re: Re: Re: Re: Re: 3020 vs 4030 in reply to Fred G, 10-24-2003 06:38:27
That could be, but every 3020 I've ever seen has had the 1000-shaft, and they are sub-80 HP and pre-1970, at least the early ones. My guess is that that 1000 shaft was optional. The tractors were equipped to operate it, but the operator could save a few bucks by not ordering it. Since the 4030 he's looking at doesn't have a Sound-Gard on it, and is a synchro-range tractor rather than a quad-range, I'd say that whoever ordered it was looking for more of a low-frills machine, which may explain why it didn't come with the 1000 shaft. My two cents, and we'll probably never know for sure.
Fred G
10-24-2003 08:47:26
 Re: Re: Re: Re: Re: Re: Re: Re: 3020 vs 4030 in reply to G-MAN, 10-24-2003 07:48:53
You're probably right. After posting I remembered that my dad's 2520 had the 1000RPM shaft tucked away in it's little cubby. Never did take that bugger out in 35 years....
Maybe the no-shaft option was bundled with the synchro-range trans to keep the cost down, but standard with quad or ps?
You're right we'll never know....!
G-MAN
10-24-2003 11:03:51
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 3020 vs 4030 in reply to Fred G, 10-24-2003 08:47:26
I'm sure a sales-department order form or options sheet for a 4030 would answer all of our questions.
Leon in Mn.
10-24-2003 18:35:51
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 3020 vs 40 in reply to G-MAN, 10-24-2003 11:03:51
I have a 1973 4030 diesel with the quad range transmission and the sound guard cab and it has never had the 1000 shaft with it. It has the "flat plate" on the side. I often wondered about why it never had the 1000 speed shaft with it or the cover, but the book shows it can be installed. It must have been an option on that model. We might never know.....
