Hard starting 2520
John51
11-30-2004 17:07:16
My 2520 gas has become hard to start in the last two weeks. It has new points and plugs but I don't think the problem is in the ignition. It seems more like fuel. It acts like there is no gas in the carb bowl and I need to crank it over while choked for far too long. Many times I need to stop cranking and recharge the battery. Finally it will hit and run perfect. Any idea what is happening?
Thanks
Mike M
12-01-2004 10:19:04
 Re: Hard starting 2520 in reply to John51, 11-30-2004 17:07:16
Before you start it next time I would take the gas line off and see if the fuel pump is pumping right away or if it takes awhile.The internal check valves may be shot.
