4230 in UK
charlesmm
11-30-2004 00:43:14
Just aquired this one to keep my 4430 company , it has clearly worked hard shows 3000 hours but that could be 13000 , the gate on the quad gearchange is burred from being hit by the lever so often but she starts well, no smoke and sounds perfect , just one problem the red transmission light only comes on while the engine is being cranked by the starter, (together with the air filter light)but does not come on otherwise .
I have tried earthing the connection down to the sender unit but that did not make it light up , the tech manual says to trace the supply back through the bulkhead to the cluster coupling checking for a high resistance or open circuit can anyone explain what this means and what I should be looking for? and should this wire be live (Hot, as you say )I keep seeing warnings about damage to the circuit board
I would not have bought this tractor if I had not learnt so much from this board
(since the pages in the archives don't have pictures , I can read them at work and people think I am working very hard! )
many thanks in advance
billyiron
11-30-2004 22:32:41
 Re: 4230 in UK in reply to charlesmm, 11-30-2004 00:43:14
I think its normal while engine is being started that these lights will come on,,, then go off when tractor is running----- --billyiron
david val
11-30-2004 04:10:30
if you have the tech manual, remove the connector from the bottom of the insrument cluster, and check continuity acc to lead colors from sender to connector. if there is coninuity, problem is probably in the circuit board inside the instument cluster. if there is no continuity, i would check first the lead to the sender, it has quite long section of unprotected single lead. give it a pull. if it doesn't 'give' it could be a bad connection at the bulkhead connector (under the hood on the right side)
you can check continuity now between sender and connector.
david
charlesmm
11-30-2004 08:07:48
 Re: 4230 in UK in reply to david val, 11-30-2004 04:10:30
Thanks for that David , I understand what you are saying ,but just to confirm that when you say continuity , you mean battery voltage rather than just an unbroken circuit as measured by the multimeter using it's own voltage , sorry if I am being a bit dense here
again ,many thanks cmm
david val
11-30-2004 08:37:47
 Re: 4230 in UK in reply to charlesmm, 11-30-2004 08:07:48
by continuity i mean that current flow in a lead is unbroken.
in this case both ends of the lead are not connected to other components, you can test continuity by using ohmmeter. reading when tere is continuity should be very near zero. you can test light by applying 12 volts to one end of the tested lead and checking on the other side (or along the line).
if it's a cab tractor, is's more likely the problem is 'outside' the cab
david
